KevtheRev
Everything posted by KevtheRev
  1. KevtheRev replied to mailee's topic in Yamaha Workshop
    Usually the manufacturer will give differing quantities of oil depending on whether the engine has been rebuilt . had an oil change only , or had an oil and filter change .
  2. KevtheRev replied to mailee's topic in Yamaha Workshop
    If the window is coated and you don't want to remove the cover you'll just have to change the oil and fill with the recommended quantity . As stated above , it could be that at present the oil level is above the window , in which case you'll see the level after the oil change .
  3. Make sure your tyres are the sizes recommended by Yamaha , and that the pressures are correct . Sometimes mixing tyres from different manufacturers , even if the correct sizes , can have a bad effect .
  4. You may find that you'll also need new throttle and clutch cables and that you may have to lengthen the wiring for the switchgear and maybe new brake lines , depending on the length of your new bars . Try to measure before you do anything drastic .
  5. Also , if you keep the oil delivery tube below the level of the Scottoiler unit all the way to the chain , it will save you having to bleed the tube whenever you let it run out of oil . Did you get it working ?
  6. Hi there , If your bike has a vacuum type fuel switch , you can "T" into the rubber vacuum tube with the little plastic three way fitting . If not there is usually a crosshead inspection screw on one of the inlet flanges . You can get a small brass fitting which replaces the screw , and the Scottoiler vacuum tube goes onto this . You'll be delighted with it . I was a courier and was getting ridiculous mileages out of chains with them . I used any free/ cheap clean oil I could find in it and never had a problem . Hope that helps .
  7. The spray cans of carb cleaner work really well . When you use it , put a tray underneath and catch the stuff as it drips off / oversprays , it's expensive stuff . let it soak and then get busy with old toothbrush . The coke and vinegar ideas sound much more pocket friendly though .
  8. Thanks guys ,
  9. Hi there people . Does any body know if the fuel tank from the air cooled RD will fit the LC ? My tank is made of rust , weld and fibreglass , leaks like a sieve , and is finished in a fetching shade of JCB yellow . I reckon it's beyond economical repair and second hands are hard to find . If anyone has any ideas , nice one ,
  10. Hi there , does anyone know of brakes from a modern(ish) bike which could fit , or be made to fit , my LC without too much fannying about ? The originals are bunched !! Cheers in advance .
  11. Hi folks , the brake calipers on my project LC are pretty much shot beyond recovery . I was wondering if anyone would know if brakes from any modern bike will go on without too much messing about ?
  12. P.s. This interweb thing is great , isn't it ! When I was trying to get parts here in Ireland years ago it was a nightmare . Now you can get everything at the touch of a button .
  13. Hi everyone , I'm Kevin . Longtime courier/despatch rider , I'm 44 riding since 17 , picked up a 4yr ban 5yrs ago (in a car) and I'm making some shapes about getting back on the road . I got rid of my trusty CB500 when I got nailed . So with my options limited by my ahem, limited means I have decided to resurrect the 1982 350 LC that has been lurking around in various locations in the folks garage for the last 10yrs or so . I had given my bro a tuned but tatty German import LC which I got as a part ex for another bike (Jeebus , but that German thing could move ) . He bought another LC to use as a parts donor but after riding it home discovered that everything on it was shagged . This then is my inheritance , bro' said I could have it if I wanted to put it on the road , nice one 'bro . 'Bro has since restored the German LC and she's a beauty . Next week I'll be sending the crank off to Chris Applebee for a rebuild . I'll keep people posted on my progress if any are interested and I'll be gleaning info from the forums , Looking forward to meeting you folk .
