aunty
Everything posted by aunty
  1. 23,00 anit too bad, as long as the oil and oil filter are changed at the correct intervals. Take it easy on her at first, building up your speed slowly over time, then if a problem arises sort it then. The one bit of solid gold advice i would give to you and ANYONE reading this article is.. if you have a bike or car with an engine thats done over 3000 miles (anotherwords fully bedded in) buy some stuff called "ZX1" its an oil aditive that comes in a bright yellow box that you can buy from all sorts of diferent places inc Halfords, this stuff was used by people who race engines inc off shore power boat racers and the Ferrari formula one team. I used to destroy engines on my race bikes a lot more regularly before i used this stuff and i wouldn't run my road car or road bike without it!! its hard to explain here.. but go search it out then read on the side of the box what it does... Trust me im not getting paid to say this crap its brilliant!! and it will make your engine last about 3 times as long!!
  2. aunty replied to festa's topic in Yamaha Workshop
    i'd say if everything lines up ok and all the spacers fit fine, the disks line up with the pads exacty, and most importantly... the sproket lines up with the chain ok (check that the chain sizes are the same!! as a slight diference here could be a headache to say the least... you can find out off the internet from someone who sells chain and sprocket sets for yamaha's) If all this is ok the it will be fine, the wheels them self will take the extra power without even slighty being bothered about it, (this i do know!) and the 180 rear on a r6 compared to the 190 on the R1 will hardly be noticeable (unless your planing to do a british superbike round on it soon?!? ) Let us know how you get on (just try her gently gently at first)
  3. it eightther sounds like an over fueling problem...i.e a sticking choke... or possibly a ingition timing problem i.e a need for a new cdi unit. i would check the choke doesn't stick, then check none of the spark plug leads are arc-ing across (best way is to start the bike in a REALLY dark place, then see if you can see any small sparks jumping across from the leads any where) if this doesn't work, get back to us and we'll try and help you a bit more (trial and error my man!!)
  4. aunty replied to dez's topic in Yamaha Workshop
    Well its old advice but its the best... look on ebay. got most of mine from there. (what you after exactly?)
  5. I would take that carb off again and go through it all step by step, making sure its all set up ok, and evrything is moving where it should be, then check the inlet rubbers are done up tight and haven't split as that would let in too much air. also make sure that your choke isn't getting stuck, i'd bet that'll sort it
  6. aunty replied to TZRAndy's topic in Yamaha Gallery
    Looks better than my 750 mate! nice little screamer
  7. aunty replied to Matt Hillyard's topic in Naked
    This is gonna sound strange to those whom have not heard of these, but Tomahawk tyres!! they are the ones who came out years ago with the first ever remould tyres... i know this sounds like suicide but i used to race with there tyres and i came 2nd in the 1300 open novice Championship with the Derby Phoenix on these little beauties. a rear tyre would cost me about £60!! and you could choose which carcas you wanted to use.. i.e michelin pilot sport, or bridgestone 010's or dunlop 207gp etc. Then they put on thier rubber.. which they get from Avon and you can choose the compound. i Used to have michelin carcases with there stickiest compound (which was essentialy a qualifiying tyre). My bike would do 170+ in a strait line and they have no probs with them at all! they even do tyres for V-max's.. so don't worry about them coming apart cause they never have yet! they even do coloured tyres P.s. i get nothing from telling you this as i haven't race for about 3 years and haven't spoke to them since then. They geniunely are great tyres- front and back. give them a look up on the internet. Dave. I belive they got the technology from retreading aircraft tyres, so its tried and tested.
  8. If it was there fault for ordering the wrong shims, they are legaly bound to replace them for the right ones free of charge, or give you a FULL refund, as its not your fault, as long as you've still got the reciept...and you didn't take 12 months to get round to try fitting them
  9. This was a tank slapper at 90 that sent me into the end of a farmers field gateway. me and the bike hit the post at the end of the gate way. The bike went up in the air... cleared the road and landed on its back wheel, then procceeded to go end over end for about 100+ yards. The only thing we could salvege was the engine, the right hand side peg assembley, the seats, the end can and the odd switch. Forks bent, swingarm bent, chassis cracked, wheels fooked, all pannels and sundries broke/smashed, tank split... Ohh how we laughed!! *cough* WHAT YOU THINK GUYS AND GALS??!
  10. hi there, i used to race an R1 so i should be able to help out bud Too stiff at rear and too slow at the front, to me sounds like because of your extra weight (just over the average which is about 10.5 stone ringing wet i recon!!?!) the bike is sagging at the rear, altering the steering head angle, and the too stiff is compression damping (and possibly rebound but don't touch it for now) Always, in my opinion start with the preload! put a bit more preload on it and take a couple of clicks OFF compression damping. then take her for a spin and see how she feels, my guess is she'll feel a shed load better! If she is better but not quite right, tell me what shes doing in more detail and we'll take it from there. Hope this helps, Dave.
  11. aunty replied to chakka's topic in Yamaha Workshop
    The pistons that push the brake pads onto the disc will most likely be very dirty and have filth stuck hard to there sides. You need to take the pads out, take the top off your brake fluid reservouir (try to put o bit off cloth around it to stop fluid spilling/splashing onto your paint work!!) pump the pistons a good way out (but not all the wat out!!) and then clean arond them. Best way i find is to use a bit of clean brake fluid and some very very fine sand paper cut into long thin strips.... put a strip around the piston and pull the one end of the paper then the other.. in a kind of back wards and forwards motion to clean around them, making sure all the time that the sand paper is nice and damp/wet with the clean brake fluid. Do this a little while till you get them nice and shinny/clean. then get a couple of strips of clean cloth and try to dry them off and buff them at the same time using the same kind of motion... then push the pistons back in, makeing sure that as you push them back in- they are going in nice and strait with a good even pressure all around. Do this to all the pistons on both sides of the bike, then pop your reservouir cap back on (topping it up if need be) Be advised.. its not a quick job!- take your time, and the better job you do... the better they'll feel when you come to use them! also before riding the bike, pump the lever a good few times to get some pressure back and try them out a bit at a time... like bedding in new pads type of thing. Hope this is of some help, let us know how you get on, cheers, Dave.
  12. the trouble with that is, carb cleaner may take away the remainder of the grease thats in there, and any lubeing will be less effective as the grease should aid it from draining away
  13. Have you tried checking your thermostat works, just replace it, it'd cost you about £25 and is do.
  14. aunty replied to aunty's topic in Yamaha Gallery
    Though i best add proof of racing.
  15. If its just a cable operated clutch, then just use a bit of engine oil, the thicker the better!
  16. aunty replied to fastrsho's topic in Yamaha Workshop
    for the sake of handling and due to tyre expansion at high speed, i personaly wouldn't go over 180. a 200 would kill the handling of a great handling sports bike. you don't need a 200 any way, its just the latest gimmic. I have a yzf750r motor with stage 4 dyno, gas flow and a race pipe in an Fzr400rr chassis and its still got the original 160 rear. i used to race this bike like this and i still won races in the 1300 open against R1's and Gsxr1000's. if you don't believe me... click below http://www.yamahaclub.com/forums/My-YZR-4-7-t6306.html)
  17. aunty replied to anand's topic in Yamaha Gallery
    I didn't think i'd salavate over another 2 stroke but you proved me wrong. very nice job old bean, v nice indeed
  18. a lot of bikes will give a little jolt as they go into first, but as you say it dies some times in first there maybe a small chance of a wrongly adjusted clutch, if it is a cable adjusted one try adjusting it so the clutch bites further from the handle bar. as for the puff of smoke... over to someone else.. sorry.
  19. that looks really good, i think the tyre paint goes well to break up the blackness, i think retro bikes look really good with the old tyre paint, i may even do mine! Top job that man!
  20. Just an opinion here but, get the carbs balanced.. get a shop to do it.. its a lot cheaper than you think! also make sure theres not an air leak into the defective cylinder.. that would explain why its there when cold but not so noticable when its warm, this could simpley be a splt rubber inlet manifold or one of the clamps that hold it being loose. if your woried it may be the leads or something like that.. Wait till its dark, take the tank off (there will be enough petrol in the carbs to start it for a while) start it then look for sparks or arcs lighting up. let us know how you get on, Dave.
  21. Due to differences in compression ratio's, bore and stroke, water pressure, internal head shape, and possible nightmare with gasskets, i would really steer clear of this one mate, sorry to say but, you may do more damage than you fix Sorry, Dave.
  22. Usualy if i remember right it'll be a pair of pliers, ascrew driver thing that has a phillips head on one end and a flat blade one on the other, two large ring spanners, one that fits the front wheel spinndle and one that fits the rear. an open end spanner that fits the chain adjusters prob 12mm one end and10mm the other...but don't quote me on the spanner. maybe a C spanner to adjust the rear suspension and a couple of allen keys... you'll have to work out the sizes buy trying the allen bolts on the bike itself. There may also bee a chance it will have a spark plug tube/spanner type thing. You may be able to buy a set off ebay if you search for one, but not sure. Hope this helps, Dave.
  23. I know its a pain in the bum... but clean the engine all over till its mint clean, then run it to see EXACTLY where it is coming from, then post back on here where you think its coming from and we'll be able to help you a little better. Dave.
  24. aunty replied to Noodleman's topic in Yamaha Workshop
    the clicking sound IS the battery being too flat, it may not be shagged though as it just may need to be charged up (off the bike so not to upset the electrics and fuses) best bet to start with is to buy a haynes manual.... it will guide you through step by step in an easy to understand way, you can get a cheap second hand one off ebay, or a new one from Halfords or your local bike shop. as for not starting it could be fuel or electrics, try your fuses first, the check the fuel is getting through ok (The manual will help you with both of these if you need it) let us know how you get on, Dave.
  25. aunty replied to Mr Pink's topic in Naked
    try a penske rear shock.. i used to use one of these on my R1 race bike, it was a lot cheaper than ohlins and realy good. try gettin a good one off ebay, or from a racres forum
