Everything posted by Simon46
- 4 Yams,
FUEL
Its not as bad. My carb varnished up in 2 mths with unleaded. Not had a problem since with super
Broken foot
I put my Oxford thermal sock on this morning as its a tight fit. This afternoon I have driven the van, walked without crutches and walked with no boot. I wasn't given a sock as fracture clinic was closed on a Sunday and the nurse could not access it because she did not have the code (not her fault). Now the healing process is accelerated?
Yamaha DT100
They rebuilt my crank with new improved conrod big end for lubricating big end,and small supplied in about 20 mins. Would highly recommend. Regards Simon
Yamaha DT100
These people did my 175 http://www.grampianmotors.co.uk/
Broken foot
Somewhere in my dads garage is my grandfather's mobility scooter with dead battery. Its 110 quid for a new one. Hmm
Yamaha DT100
What country are you in?
Broken foot
Cheers guys. Hyperbaric chamber I would like but I dont earn £100000 a week. Yes am still alive and have watched telly for 16 hrs! YouTube, discovery, mini moke refurb, submarine u boat hydrogen peroxide propulsion, etc. I even want to convert that boot into an xt500 kickstart aid. Its strange having time on your hands to think...
Broken foot
Hi all broke my right foot getting out of the side door of my van after going to get a part. I tripped over something and landed sideways and rolled my foot over. Stepping hill hospital have given me an xray, aircast plastic boot,and crutches to repair my fractured cuboid and no 5 metatarsal bone. Is there anything you guys recommend that can speed up healing from experience? Am told to do nothing lie on the settee but elevate it. Regards Simon
DT 175 E non starter.
Do the carb. I did mine twice. Unfortunately the piston rings were in the exhaust. Have you got compression?
DT175mx clutch grabbing
Is it a jumpy feeling when pulling away?My 175mx did this with new metal EBC clutch plates and replacement used basket as I had clutch rattle with the rivets. Im considering changing it back to the Cork plates and old basket.
Don't ignore that 'feeling'.
Wow glad u ok. Chains scare me that much I bought digital verniers to measure the rivet link on my 1200.
Arrrrgh, teenage bodgers....
I planned on 3 months and 400 quid. 2 years and 2200 quid later im not sure im still finished
Dt175mx rumble in top gear
Schoolboy no tools 1970s mechanics! They did the same with the steering head nut. The guy who bought it brand new (now passed away) forgot to put 2 stroke in it. It sat since 1980 after a rebore in Ashton which the guy didnt chamfer the ports. Rings broke after 15 mins running. Because the sprocket nut was original I thought I would keep it.
Revs to speed in top gear. 30 mph is 3000 rpm, 50 mph 5000rpm. Can hold it on an incline under the powerband. 90 is 9000 rpm.
Rear sprocket sizes
Yes if you do check the chain isnt rubbing more against swingarm if it does that already.
Stafford Show
+1 on the yz stand
Well went out for a first blast today since sprocket change. All I can say is wow! I can keep the front wheel on the ground and where I would have been in sixth gear from the lights I am still in 3rd with the 17t front sprocket. Gear changes are about 6-8 seconds apart. The swingarm roller seal guard is not touching the chain anymore and is smoother ride. That was brand new when fitted and has been busy looking at the grooves in it. No play or oil leaks detected in shaft. Probably if I adjusted the rear shock to softer it would have given the same effect. Feel like it's an Rd200 but with knobblies on. Dont forget im 1.50 oversize and energy induction fitted too. It now feels like I could ride it for longer distances without fighting it all the time.
Well the 17 tooth is fitted. It just fits. The 15 is here which I had to get the windy gun to remove It now clears the top of the swingarm chain roller with the 17 tooth just.
They have arrived. Not a lot of clearance between swingarm roller and sprocket
I saw one on bonis hall lane on my way to macc about 3/4 yrs ago. Was a couple of riders with him. Thats the only one ive ever seen
I feel for you. The crack in my 175mx gear lever side crankcase was bodged with silicon sealant
First ride out today. I did tension chain to 50 mm when fitted new as of Haynes manual (Sorry thinking of the bandit 1200n) Its the rear sprocket that has worn teeth. Tensioned again sprockets not arrived yet. I expect tomorrow Oh it broke down at sainsburys cheadle on the roundabout. Luckily it was out of super unleaded! Fuel tap on reserve setting now leaks as well. It was fine in November when I last rode it! Good to be on him again.
Well ordered a plus 2 17t if it fits and a plus 1 16t as well. Arriving tomorrow so I can check shaft at the same time. Will post on results
What triumph scrambler is it
Thank you. Wasnt sure with the really small seat on it.
