Everything posted by Simon46
Picked up a new yamaha today
If you like trance and boats this is how it should go. Look at the 15 ft prop wake!
xt 600 1991 rear brake prob
I so love the e. wish id never sold mine! pissed oil but never missed a beat.
Well after many hours and also building a dva adapter for multimeter to test cdi reconnected cdi in unpotted format to test and she sparks. connected fuel and on 4th crank she ran. that twin pot two stroke is loud with the exhaust prop out of the water! love it when you fire an engine for the first time. Had to pull plug caps off to stop her though.
Replacing a throttle cable
Perhaps a wire became dislodged on the cable route?
Never Ending Bad Luck
Poor kitty. Hows he behaving? Glad hes back!
Dead bandit = new bike
Nice bike. How does it feel compared to the gsf? done an oil and filter change on my 96 b1 1200 14 K now all I can hear are noises! Its the time to buy
Polite think bike hi viz jackets
But if you look like a policeman? would drivers stop texting at the wheel? http://www.ebay.co.uk/itm/like/172232097452?lpid=122&chn=ps&adgroupid=27378760866&rlsatarget=pla-181484326386&adtype=pla&poi=&googleloc=1006620&device=m&campaignid=620865095&crdt=0&ul_ref=http%3A%2F%2Frover.ebay.com%2Frover%2F1%2F710-134428-41853-0%2F2%3Fmtid%3D1673%26kwid%3D1%26crlp%3D110919892746_563391%26itemid%3D172232097452%26targetid%3D181484326386%26device%3Dm%26mpre%3Dhttp%253a%252f%252fwww.ebay.co.uk%252fitm%252flike%252f172232097452%253flpid%253d122%2526chn%253Dps%26adtype%3Dpla%26googleloc%3D1006620%26poi%3D%26campaignid%3D620865095%26adgroupid%3D27378760866%26rlsatarget%3Dpla-181484326386%26gclid%3DCjwKEAjw19vABRCY2YmkpO2OzTsSJAAzEt8sgMC0KyiSs8hCMqETtQANwqqap6ITwc58F_rmYcxF2RoCbevw_wcB%26srcrot%3D710-134428-41853-0%26rvr_id%3D1117382452522
What you guys think of these? keep seeing a rider with one on and it definitely has an effect on my noticing him when driving my van
picking up a TDM850 Mk2 saturday
Did you pass a 1996 red bandit 1200n onthe m62 in the slow lane on your way back? My vw caddy 1.6 broke injector 1 and I was riding back from Dewsbury to cheadle sat afternoon after picking up a good one from breakers. Frighteningly high wind so much so I wanted to pull over and stop!
dt 175 clutch
Ball bearing +1
Its a big engine 2 cyl 2 stroke 800 cc. Cdi had crack through the potting as if something has gone pop and its been left outside for 2 years. Needs replacing anyway. All discrete components internally not a chip in sight. Just scr's caps diodes and resistors.
Well depotting the cdi. Should have over 100 volts to the coil. I have 17. Over 15 hrs work to get this far!
Put halfords own brand oil in my dt175 mx
Well drained it put the castrol power1 oil back in all is well after 10 miles. I didnt think it would be that fussy!
Cant even tap it down. Have to stay in first at lights.
Ok gone to find the bottle. Original is castrol power 1 10w-40 4t. Halfords is 10w/40 4 stroke motorcycle part synth engine oil. Neutral was fine 7 days ago. Clutch drag now I expect.
As above all fine before now wont shift into neutral when I topped it up. Neutral ok when stopped Beware!
motorcycle re-registration.!!!!!!!!!!!!
One for Paul Dawkins?
All safety devices will be reinstated once engine fires. Ive seen prop versus leg. It ain't pretty.
0 at the moment. No spark. Too many safety devices on the throttle. In gear no start cutout and wrist lanyard if you fall out the boat it unplugs and kills ignition. I will be starting by bypassing these to see if motor will run and go from there. Cant be as expensive as a DT175mx field bike resto! S.
- bikers attack car driver
- Bandit electric help
- Dt175mx biggest front sprocket
The rimstops turn it into a counterweight!- Dt175mx biggest front sprocket
Yambits DID 15/49 combo. Not looking for top speed just staying longer in the gears. Wemoto show a plus 2 sprocket might just try a 16 first.- Dt175mx biggest front sprocket
As im peed off going thru all the gears in 5 secs what will fit?
