rwd
Everything posted by rwd
  1. rwd replied to rwd's topic in Yamaha Workshop
    Fitted a Peugeot Speedfighter lighting resistor works perfect
  2. rwd replied to rwd's topic in Yamaha Workshop
    I didn't have a resistor that's why I needed to know the ohm / watts to be able to get one. Got it sorted now one from a Peugeot speedfighter works fine
  3. YB100 Is it ok to have the 2 stroke tank outlet pipe lower / level with the 2stroke pump ? Is the pump craving feed ? Thanks
  4. rwd posted a topic in Yamaha Workshop
    Could someone please tell me the Ohms & Watts for the resistor on my YB100. It's the one with a single black/yellow wire going to it. It should be near the rear light but isn't. Thanks
  5. Sorted, broken wire in the loom under the tank
  6. If I put a live from the battery to the brown wire on the front brake light switch everything works as it should. So there must be a break in this wire somewhere
  7. Thanks will go and have a look. Give me anything mechanical bike car lorry engines gearboxes etc no problems electrics puzzle me
  8. Got my YB100 sorted now the RXS has decided to play up. The problem I got is the horn - indicators & brake lights aren't working. the headlight - sidelight - rear light works. Tried a new battery but still nothing. Any ideas
  9. Problem now solved running great
  10. Where is the best place to get lighting / charge coil and Ignition source coil or complete stator for a 1985 Yamaha YB100
  11. rwd replied to rwd's topic in Yamaha Workshop
    Hopefully may get a chance to have a look tomorrow.
  12. rwd replied to rwd's topic in Yamaha Workshop
    Doesn't run, but have a spark
  13. rwd replied to rwd's topic in Yamaha Workshop
    I have a blue spark, I havnt touched the stator plate, and set the point to what the manual says
  14. rwd replied to rwd's topic in Yamaha Workshop
    Woodruff key is ok. Whats the best way to set the timing ? Ive done it the old fashion way ive always done piston at tdc and set it like that.
  15. My YB100 wont start. When I got it it had been park in a garage since 2011 I cleaned the carb flushed the tank and it started and ran fine for about a week then decided not to start. I done a compression test and it was low so fitted new piston and rings and gaskets. The barrel looked ok. Still wouldn't start. Stripped and cleaned the carb again fitted new condenser - points - coil - plug - plug cap and done another compression test and its 100psi have a good spark. I put petrol down the plug hole and quess what ? Still wont start. Am I missing something that's staring me in the face ?
  16. Just joined after having a look. Seems like a friendly and helpful forum. Ive got a 1986 YB100 1996 RXS 1978 Suzuki A100 Two PK Vespas and my 8 year old son has got a Honda PF50. Also I got a 1959 Ford Popular 100e with 1660 crossflow, type9 5speed box Escort suspension steering etc.
