I have recently joined this forum , to get some knowledge and advise from Yamaha lovers.
I have 50cc Yamaha neos scooter, it not powerful enough as i need to travel to work on A roads which speed limit is minimum 40 mph.
So i have purchased non runner Yamaha YBR 125 which been standing for two years. I have experience fixing bikes with carb, but I never had something with fuel injection system.
After I got it in my yard I have took it apart cleaned tank, all hoses, filter, fuel injector,changed oil and it didnt start so I started narrowing down the problem, it creates the spark so I have looked in fuel feeding and noticed there is no fuel coming from tank to ejector.
I took out fuel pump and connected to power and tried to start bike and once I turned ignition on it makes click noise and once I trying to star its not doing anything and gets a bit hot, can it be blocked? also I put some fuel inside fuel line from tank to injector and tried to start it just to see if fuel injector will work, but its not taking fuel in is that because the pump generates pressure or it could be blocked to?
Thank you
