tomyqss
Everything posted by tomyqss
  1. yes they should be a drive crank seal, but when the sprocket on it helps too keep the seal/collar in place...put the sprocket back on see if the leak stops....if it dosn't then you may need a new seal the other problem does sound a bit like a fuel problem, but electical an coils can do the same as you described too.. i'd start with the basics, like..... fuel lines, vacuums, breather pipes ect ect an go from there
  2. you don't need a kill switch for the mot, but if theres a switch there, then it has to work for the mot
  3. tomyqss replied to dav a's topic in The Bar
    i find the BBQ paint a little more better then the UHT paint
  4. my hornet did something similar, that turned out to be a exhaust seal
  5. think he means the adjustable kind..... more flex in them an can move in both directions, harded to break if you drop the bike but i don't know which ones will fit yours, have a look on ebay they usually tell you what bike they will fit
  6. tomyqss posted a topic in Video Section
    cool trailer, not sure if the dvd is out yet though
  7. tomyqss replied to tomyqss's topic in Yamaha Workshop
    lol yeah made my head hurt a bit looking at pictures he sent me trying to compare the two.... i'm not sure if the ybr changed after 2008, but it looks the same from the outside, i'm pretty sure the bottom ends/gearbox ect are the same... i know his front end is totally rote off an the frame has been bent but rest is fine.....the only other option would be to change it all, fuel pump, loom, injector cdi everything, might make a nice project for me....thats if its possible
  8. tomyqss posted a topic in Yamaha Workshop
    so i know someone whos breaking a 13 plate ybr 125 as it can't go back on the road after a accident... but the engines fine, i know ithe ybr is fuel injected an the xt is carb.... my question is, do any of you guys know if i can put a carb on the fuel injected ybr an it would run like the carb version ? or if i can swop the heads on the 13 plate ybr with a xt125x so its becomes carb ?
  9. the regulars/staff prefer you to post a introduction before asking for help bud...its a curtsy thing as for your problem, the float could be sticking, did they check the float? or it could be needle and seat is your fuel vacuum tap working correctly? no fuel should be coming out when the bikes not running
  10. its only there on tickover, an goes away after a ride.... i changed the cam chain an the rings, new gaskets, valves adjusted ....an i did put some additive in the fuel before this started but it was fine after all that , then left it stood for a few days an it just seem to appear
  11. Hey slice I always like your replies lol yup i agree! he's a tit, (still a friend though even if he has a nipple for a head) same bloke that told me i wasn't tapping the flywheel puller hard enough.......so he hit, an he it that hard he bend it! problem is, it wasn't making that noise before
  12. finally got around to taking the head of to investigate, still no idea what it is...but im learning towards the idea of it being the cam shaft? i did ask at the shop about if they had ever heard of a 'squeaky valve' they said no, so i'm a bit confused why i got told thats what the problem was.... anyways, after a visual inspection everything looks fine, so i've uploaded a little vid of the 'squeak' to see if you guys have any idea https://www.youtube.com/watch?v=-OyDfY3aqv8
  13. yes, poor excuse that...maybe the confusing your bike with the sr-71 blackbird
  14. lol no i don't want to hear that.....i'm going to take the cover off tomorrow an investigate thanks slice
  15. Hey slice Intake exhaust valve he says it probably is
  16. my xt125x has developed a squeak, only on tickover an goes away after a short ride... been told its a squeaky valve, but why would it just start squeaking overnight...it was fine the day before but more importantly, how do i fix this....i've not stripped the bike yet so not had a look at the valves to see if its getting oil. thought i'd get some more opinions first, see if you guys think it could be a squeaky valve or something else
  17. i have a universal speedo fitted to mine, i agree with all the above.... don't waste your money buying genuine new or seconded hand yamaha ones, they will just break
  18. tomyqss replied to tomyqss's topic in The Bar
    no, no sump guard fitted when i bought it, exhaust was chrome an rust i believe
  19. tomyqss replied to tomyqss's topic in The Bar
    i've done alot to it new cam chain rings top end gasket set valves re set tyres chain/sprocket kit wheel bearing break pads oil plugs filter gave it a spray fix front an back light, an indicators new clutch lever couple things let it down has universal speedo fitted, an a rip in the seat, could do with a new battery other then that, starts first kick... but yeah, think i'm going to go the ebay route....kinda miss the 2 stroke smell an sound
  20. tomyqss replied to tomyqss's topic in The Bar
    750ish sounds ok to me.. i did put it on one of them fb pages in my area......i was getting messages asking if i want to swop it for a puppy staffy an phones an all that crap lol i think i will put it on ebay like you say thanks wild foamy
  21. tomyqss posted a topic in The Bar
    looking to sell my 05 xt125x, an maybe get a 2 stroke dtr or something similar.... but i have no clue how much to put it up for... any one know how much they going for in good condition? http://imgur.com/C95ecVO
  22. or your radiator cap is not giving a good seal
