JGreen27
Everything posted by JGreen27
  1. Been a while since last update. I will keep it short . Got the throttle cable and installed it. Just got done doing another carb cleaning. After those two things it's runs great. I just rode it about 5 miles on a back road and it stayed around 35-40 the whole time. Sent from my iPhone using Tapatalk
  2. Ok great, what is the standard turn for stock? I think I have it on 1.5 turns out and it seems a little lean so I will richen it up. Dt honestly I do not know where there is a track close by I will have to look on Google. There's really not many people that ride around here most everyone has four wheelers. Sent from my iPad using Tapatalk
  3. Ok I am going to be a novice again. I know a chainsaw has an h and an L adjustment for mixture. Does this carb have the same adjustments? I am having problems getting it to idle and pick up gas when starting. Any adjustment tips would be well appreciated. Sent from my iPhone using Tapatalk
  4. Ha good point!! Just wondering. I am really surprised at how much power it's has for a fifty. Now all I have to get is a decent throttle cable. Oh btw the cows are a little nervous about a silencer less two stroke. Thanks for all the help dt. Sent from my iPad using Tapatalk
  5. Ok sounds like a plan. I have not got a chance to try the system. But I was able to ride it a good bit today. It is running ok. It pulls 1,2,&3rd gears really well but it does not like the others. It won't get enough rpms to get to power band in 4th. I think it may be a carb issue. It has a hard time kick starting. What should the compression be at? If it has low compression would this cause the lack of low rpm power. In power band it pulls really well, it's just the getting it there. Sent from my iPhone using Tapatalk
  6. I have not added any oil to the system. I have just been running mixed gas. Which would be better bypassing the system and just running mixed oil or using the injection system? Sent from my iPad using Tapatalk
  7. Ok gentlemen today's update. I put the carb back on and began trying to crank it. It required gas directly in the carb and it ran for around 10-15 seconds but never picked up from the carb. I figured it was some left over trash, so I repeated this process for around 30 min and each time it ran longer. I rigged up a makeshift throttle cable and was able to rev it a bit when it was running and this helped greatly. I put about half a liter in the tank and got it running again. I was actually able to ride it around the yard! Made my day! I was really surprised at how strong the little bike is especially when it gets up into the powerband. When I called it quits it was idling great and was beginning to run a little hot. I added water to coolant system and noticed some oil and particles. Hopefully it is just from it being in the weather so long. No questions tonight just an update. Thanks Jake Sent from my iPad using Tapatalk
  8. May be a couple mLs in the tank. That could be the reason. I teach high school science so metric is fine (better even). I thought it might be rich so that's a good thing. I will drain out the Coolant to check for droplets. Thanks for the info. Sent from my iPhone using Tapatalk
  9. Ok gentlemen just called it quits for tonight. I was able to get the carb somewhat clean but it is not good enough. Throttle cable is broken so that's a problem. I was able to get some gas in the bowl and it was enough to actually ride it. I held the throttle about half. Ok so as usual I have some questions. 1. After running it a couple times I noticed lots of black oil in the exhaust. I immediately thought it was somehow pulling oil from the tranny. I pulled the cap and the oil in the tranny was white. Anyway why is there so much oil? Could it be bad rings? 2. If it is rings can I just put new rings on it and hone the cylinder or do I get piston and all? Sent from my iPhone using Tapatalk
  10. Filter screen was inside got it out thank you sir. Sent from my iPhone using Tapatalk
  11. Well we have done it before on tractor tanks and it seemed to work ok. Is there a better way? Sent from my iPhone using Tapatalk
  12. Ok thanks guys I will try my best just to clean it really well. Just found a good bit of rust in the tank. In the process of rolling ball bearing sized rocks around in it to free it up. Any other tips on cleaning it up? Sent from my iPhone using Tapatalk
  13. Ok good news checked the radiator and it was full of antifreeze so oily substance was not coolant. Also was able to get enough gas in it to let it run for 10 or 15 seconds and it ran great. Just took the float bowl off and it was filled with white crusty material. It is currently soaking in carb cleaner. Let me ask a question, it is a mukini and I can get a kit for around 30$ but I can also get a new carb (unsure of brand) for 30$ also. Which would be the best approach? Sent from my iPhone using Tapatalk
  14. Frame number:jya3bka04jc003500 Sent from my iPhone using Tapatalk
  15. Ok guys after doing more research and looking closer at the bike I realized that I have made a big mistake. It is not a DT 125, instead it is a DT 50u. I am sorry for the misleading identification. That would explain why it is so easy to kick over. Now I go back to my original question, is it worth fixing since it is not a 125? All I will be using it for is checking on cows and moving around the farm. Will it pull me? I am 6'1" and 210lbs (95kg). Once again sorry about not knowing what I am talking about. Thanks Jake
  16. Thanks for the reply guys. I am going to work on it today and will hopefully be able to post some pictures. I am from Alabama and have a couple of Yamaha dealers here close so I will check with them about parts. Also, I have ordered some parts for fourwheelers from cheapcycleparts.net and they seem to be a reputable website to order from. Have any of you had any experience with them? I will try to do a compression test today and will tell results tonight. Thanks for the help gentlemen. Jake
  17. My name is Jake and I am new to motorcycles. I own a farm and have worked on many tractors, chainsaws, dump truck, etc. but liquid cooled two strokes are new. Ok, so in laws have a scrap collecting business. Yesterday I was rummaging around and found what is left of a DT 125. I am not exactly sure of the year and info on finding that would be helpful. I got it out of the scrap heap and began looking it over. It is missing the seat, rear fender, and some other odds and ends like blinkers and tail light. Mechanically it seemed intact. I kicked on the kick lever and the engine rotated about 1/2 a revolution and stopped. I removed the spark plug to examine piston and cylinder with flash light and cylinder was full of water and oil. Could this be from laying on its side for 2+ years? Or is this a major problem? Anyway, got the rear tire freed up so it would roll and turn the engine over. After a couple major sprays of the watery oily mixture the engine freed up and turned just fine. I pushed the bike round for about 15 min until most of the oily substance stopped coming out. Then I removed the exhaust and more oily substance poured out. Needless to say I believe I have gotten most of the fluid out without removng any major mechanical parts like head or cylinder base. Out of pure curiosity ,and after I saw some spark from the spark plug, I poured just a little gas straight into the cylinder. After a few kicks it fired and somewhat ran for 3 or 4 seconds. I stopped working on it then because I am a newbie to motorcycles and wanted to ask some questions. Questions: 1. Everyone has said these bikes are a joy to work on, so does anyone think I can get it running good enough to ride about on the farm for lets say less than 500? (I would like it to move me and it under its own power.) 2. The compression seems low. I can kick it over easily with my hand, just by pushing on the kick lever. Does this scream new top end? If so, where can I find a complete top end kit? 3. Lastly, if this bike is worth some clean up and money, how much is too much? I don't want to drop 2500 or some high amount into something that is not worth it. 4. How do I find the year in the serial number? 5. Why was there oily fluid in the cylinder? Thanks ahead of time for your time and any information Jake
  18. Hello my name is Jake and I am from the US. I have recently rescued a DT 125 from a scrap metal pile. I really would like to get it running and be able to ride around the farm and check on cows. I hope, with help from this community, to be able to do that. Thanks, Jake
