Ogwen
  1. Ogwen changed their profile photo
  2. Hi all, the chain and sprocket swap is done! I used the grinder for the chain no problem, and plenty of plusgas to loosen the bolts on the front sprocket cover. All good! Next job, headset bearing....
  3. Nope West Yorkshire - The story behind the ogwen nickname is a long one:)
  4. Have grinder so that solves that problem:) - Thanks for your response
  5. Hi everyone, I've read the chain thread that is pinned above, and I am happy tackling it. I have a garage with light and power to do the work, and plenty of tools - I could just do with tips on what tools are needed to swap everyting over? I'll consult the Haynes fairy story manual but I'd rather hear from someone who has done the job:) I've found a place that will do the chain and sprockets set for £40 delivered whichs sounds ok Any help gratefully appreciated. Cheers Ogwen
  6. New member here with a 2008 YBR 125 - Mainly here as a DIY mechanic looking for help advice and to offer the same. Hopefully doing my full test this spring and then will be getting something bigger!
