cliffj
Everything posted by cliffj
  1. Thanks Have done the drive pin and cam tensioner . so will check starter nut. Cheers
  2. Hi Just hoping someone can help I just bought a Diversion 600N , 1995 and when I got it the you could not get it into gear . I found the thrust bearing gone so replaced and all ok in that department now . When I started the bike it sounds like a bag of nails under 2000 rpm , so I have stripped cleaned and balanced the carbs , removed the clutch basket and checked out the gearing drive behind and replaced the drive pin as a precaution. Has anyone any idea what it could be there are other bikers with the same problem on You tube but no solution as yet . Many thanks Clive
