Hi
Just hoping someone can help I just bought a Diversion 600N , 1995 and when I got it the you could not get it into gear . I found the thrust bearing gone so replaced and all ok in that department now .
When I started the bike it sounds like a bag of nails under 2000 rpm , so I have stripped cleaned and balanced the carbs , removed the clutch basket and checked out the gearing drive behind and replaced the drive pin as a precaution.
Has anyone any idea what it could be there are other bikers with the same problem on You tube but no solution as yet .
Many thanks
Clive
