Yamaha Yzf R125 Stolen Now Has Neutral Light Problem
not that i can tell but i cant work out whats what on the wiring sheet i has the numbers next to parts but it does not show where on the bike the part is :/ (looks like i might have to take it back to the garage and pay them to work it out maybe they will be able to reed the wiring sheet) only reason i didnt let them work it out as they said they didnt know how much it would cost they would have to look at it first and charge me as they go along :/ thanks for the help anyways
Hi, Thanks for the info I have the service manual :] on the wiring diagram i have a number 14.neutral switch or 62. neutral indicator light would that be the best place to start looking then thanks again for all this help
hi, thanks for the reply from what the bike garage told me the only wires damaged were on the ignition and they replaced the hole ignition thing for me. would i be able to find out where the inhibitor wire is from my yamahar service manual? and would this solve the neutral light or is that the issue thats making the inhibitor think different? thanks
hi, thanks for the reply the bulb on the unit is fine as it does work on the odd time so im thinking its something loose but not sure where to start. it was in good condish when i got it back they stole my petrol cap snaped the stearing lock and cut the wires to the bikes ignition broke a side panel and bent my brake leaver (last part may have been from them dropping it to the ground)
hi fellow riders
just saying a quick hi i found this forum when looking for a place to get advice on my bike which was stolen and is now not working. im from the uk and have rode a bike for about 2 years nows
Hi, My bike was stolen and after getting it back it will no longer show the neutral light when in neutral (the light is not broke as it has worked for me once when i was driving it the other day i put it in neutral and it worked) when the light is not working I can not start the bike with the kickstand down even when in neutral gear and the bike will also only start with the clutch is held in. Do you have any advice on what could be the problem? also I know It goes into neutral because im able to move the bike without holding the clutch and also when starting the bike via holding the clutch in I can let go of the clutch and it will idle for me Thanks for any help
ldog85
Joined
Last visited
