		xt250 6v 12v Conversion?
		it's cdi, now i see why it was sold on, to much money in to it, to stop now.
		Any wiring wizards out there!, Restoring a 81 xt250 bought as a non runner, problems with the wiring etc. I bought a new 6v xt loom, New ecu, 6v coil, switches etc, Now had a look at the stator at the weekend and discovered it's from a sr250, which is obviously 12v, also the reg-rectifier is off a sr250, so don't know, is it best to try and link the stator to the 6v loom or get a new sr 12v loom and start again, is there much differance? any one done this in the past?, any one got a xt250 stator they want to sell?, none on ebay at the moment. Am a little lost at the moment, Any help would be great, Tony.
		xt250 ecu
		Hi tommytenbikes. Got myself a new yamaha ecu (169 pounds) 3y1-20 , now starting to fit this, slight problem. The new loom i got has two red wires with the other wires for the ecu, there is one red wire coming out of the ecu, has yours? We sent a test down one red wire with a spade conector, and the other end was the battery red wire, this is a after market loom, not a yamaha one but they say it is the same, ie 1980 to 83 uk and europe, any help will be Appreciated. many thanks Tony.
		xt250 ecu
		Need help, rewiring a xt250 non runner, fitted a new loom, switch and coil, the cdi i got is not fitting my loom, think it not a bike one. i like to make it a 12v system, do i need to get a 6v ecu or later 12v ecu, the regulator is a 12v one, any help will be great! many thanks Tony.
		yamaha xt250
		Tommytenbikes, many thanks for sending the wiring diagram, the area i stuck on is the ecu, the one that came with the bike is off god knows where,a car i think, trying to convert it to 12v, have you converted yours to 12v?, if i buy a used ecu do i need a 6v early one or later 12v one if you or any one knows it will be a great help, Tony.
		yamaha xt250
		Many thanks, the bike look GREAT!
		yamaha xt250
		Hi, just pop in to say hi, new member today, i am in to xt's and got a xt500 and a xt250. the 250 is being done up at the moment, having problems with the wiring, but can't get hold of a good wiring diagram for a 1981.if any one got one it would be helpful,the rest of the bike is coming on ok. the 500 is working great. will look in again tomorrow, Tony in cornwall.
bikecrazy100
Joined
Last visited
