Doomsnite
  1. Well the Leoch has died it appears. Last volt reading 8.6 with ignition on, then 11.6 when engine running after kick start. Would charging the battery and checking discharge time/do another volt reading tell me anything different or should I just go for a replacement battery? The fact the volts are higher when the engines running shows there's nothing wrong with the rest of the bike doesn't it? Just the batt? Is Lextek a decent brand? How would I know a decent brand? I'm oblivious to batts.
  2. So Ive been having some battery problems. Bike wont start on start button, only kick and I now the the 46 error code which means battery problem. Voltage is low on the batt so ordered a charger so I can do some testing on that. NOW, i realise the battery is incorrect. Yamaha parts list starts to use a YTX7L-BS Yuasa battery which is 6amps but the one i have is a Leoch LB5LB which is 5amps. Could this be the source of all problems and a battery swap will sort it out? Further to that, if i need a battery, will only the Yuasa work or can I use any battery of the same type (YTX7L-BS) I have seen Lextek on ebay which is a lot cheaper than the Yuasa - but do you get what you pay for and recommend any brands?
  3. At least If they matched then i know it was the engine it was manufactured with and could trust the mileage on the mots
  4. Also it concerns me that it could have a different engine in and dont know how that might have been used/abused
  5. Bought my first bike and stupidly didn't check this (didn't check VIN either but luckily that matches). V5 arrived today and the engine number is different. On the bike there is 2 lines of numbers on the engine and looks like this.. *E399E-* then 2nd line looks like this (i put questions marks where the actual numbers are: *??????* On the V5 it looks like this. I put question marks for some of the numbers.. E399E0?????? So the first few characters match but basically not the 2nd line of the engine. The owner didn't mention anything, I know I should have checked and asked but is this heard of to have a partial mis match before I go back and ask the previous owner? Should I inform the DVLA of the change if the previous owner does/doesnt know about it? Is there anyway I can investigate further? Its only had 2 MOTs due to being 2009 and the mileage seems to tally up. Not sure if I should be concerned or put it down to experience. I guess I am more concerned of notifying someone in case the engine was stolen or struggling to sell it due to people being more vigilant than I was.
  6. Which fitting bulb do you need for the 2009 model? and what wattage is recommended to bump it up as mine is weak too.
  7. Sorry for old thread. 2 things 1 cant convert language using that link above and the GB flag. 2 What size spanner do i need for the job? I dont have any tools and need to get some in order to do this
  8. Turned out it was battery. Kick started worked in the end. Multimeter confirmed its dead. Ordered a charger to charge it up and confirm whether battery needs replacing. Shouldnt really die after a week. thanks all.
  9. Never had auto lessons when I was at school.. plus it was like 16yrs ago.
  10. Which fluids? I did the oil and put a bit too much in. Could that be a factor?
  11. Could it be battery, even if it started 30mins before and had been ridden throughout that 30mins?
  12. So, haven't run it since buying it last week, go out this morning and didn't start on first button press. Turned it off and tried again and it started. Continued to start a few more times throughout the morning whilst I was checking & topping up the oil and before I went out for a ride. I managed to put a little too much oil in so it went above the max marker slightly. Now, during the ride, went to the garage to check the tyre pressure and when I pulled up, i put the side stand on with the engine running so it cut out. Did the tyres and went to start up again and wouldn't start. Tried a few more times and each time the starter was struggling more and more. I left it for a while and just sat there thinking about starting to walk it to the nearest mechanic in town when I thought about jump starting. So walked with it and let the clutch out and it started - almost run away from me but managed to grab it. Rode home but noticed when stopped at a few lights, the revs were dipping on idle a bit. Left it for an hour and tried to start again a min ago and wouldn't start. Tried to kick it over and didn't start either so now wrapped it up again and looking for help for what to do. Only things I noticed were different to normal are: too much oil engine stopped with kill switch on side stand before it wouldn't start again TLDR - electric and kick start doesn't start engine, symptoms sound like when my battery is low/dying in my car but it had just been running minutes before
  13. Thanks for the offer.. very generous. I'm over in Stevenage though unfortunatly. Think I might give it a month or so.. get some much needed miles under my belt now. Although the weather isnt helping! I did my CBT in the gales and rain over xmas, so if I can ride in that I can ride in anything!
  14. Thanks for that. I was planning to attack some of the bolts with WD40, is that as good as Plusgas? Also would you recommended wacking ACF-50 all over it now too?
