Hitchen187
Everything posted by Hitchen187
  1. Iv only had inlet side apart on bike so ill check them is it possible to fit reed valve upside down
  2. Is that the block that has a spring above it that screws into carb and moves up and down when you twist throttle
  3. The inlet manifold is tight on the carb could the seal between the reed valve, engine and inlet cause this problem
  4. Do you mean by throttle slide the end of the rev cable because thats seated fully in the carb and is it possible put reed valves in upside down
  5. Hitchen187 posted a topic in The Bar
    Hi guys please help me iv got a dt 125 1999 and its got a running issue theres 2 issues i think 1stly the bike would tick over but when i ride it i get 300 meters then bike cuts out almost asif being starved of fuel so i cleaned carb today and put back together now bike only runs with choke on but its revving its knackers off i did take inlet off and toon reed valves out aswell can any1 help me
  6. Hitchen187 posted a topic in General
  7. Hi guys please help me iv got a dt 125 1999 and its got a running issue theres 2 issues i think 1stly the bike would tick over but when i ride it i get 300 meters then bike cuts out almost asif being starved of fuel so i cleaned carb today and put back together now bike only runs with choke on but its revving its knackers off i did take inlet off and toon reed valves out aswell can any1 help me
  8. Hi guys please help me iv got a dt 125 1999 and its got a running issue theres 2 issues i think 1stly the bike would tick over but when i ride it i get 300 meters then bike cuts out almost asif being starved of fuel so i cleaned carb today and put back together now bike only runs with choke on but its revving its knackers off i did take inlet off and toon reed valves out aswell can any1 help me
