tony20006
Everything posted by tony20006
  1. Thanks, I've just picked a new plug cap for it and have noticed it actually starts better with the side stand up . Can't really figure that out yet as it should only affect the running if you put it in gear with the stand down . I'll bypass the side stand anyway for now , also tried a different cdi and doesn't make any difference . I'll have a play with the mixture settings
  2. Hi, My sons dt has started having problems starting .new plug fitted ,not the best spark I've seen but should be enough. I've stripped the carb and cleaned the pilot and main jets .shes firing on the starter but won't catch and pick up . If I keep her spinning long enough with the throttle open she will catch and run. As soon as you let the revs die she cuts out . Any ideas as I'm running out of obvious ones before I think about big uns like crank seals
