jd9995
Everything posted by jd9995
  1. I revived my genuine regalater and replaced it and the fuse doesn't blow so the cheap ones on eBay (do not work) so that's sorted but still have the spark charge and lighting prob thow have had a new coil put on it to so get the meter out tomorrow and check everything agen
  2. Hi there thanks for the coms I have looked all over the loom and connectors and everything seems to be in order but one weird think was I used the meter on beep setting and got a positive reading from the negative to the positive and the did a test from the postive on the bat to the frame and the lights lit up :S so think its got to be. the rectifior
  3. Hi there am new to this so here goes I got an aerox 50 rossi 06 as a project had bike with no fairings and no head light got the parts and aftermarket head light put together getting it ready for the moto and noticed the lights were dim and lack off power as if it was running off the bat then would run out of spark till bat was chaged agen iv check the stator and is giving 13v out so thought it my be bad earth used the meter agen and all earths seem ok so then moved on to the regulator I ordered a new one looks the same cheap new one on ebay pluged it in and is fine when turn ignition on but soon as u kick it or use the stater n engine fires the fuse blows so ordered a new thinking my luck may be faulty one new one came and same agen blowing 10amp and 15amp fuses and also have done this with the headlight connected and discounted any help would be great so puzzled by it and thanks for reading
  4. Aerox 50 rossi 06 wiring problem hi there new to this so here goes my aerox is running but has no power and lights go dim it is like it is running off the battery put the throttle on for a bit and runs out of spark I thort bad earth but seems to be earthing ok so moved on to the reg ordered one and plugged it in so as the bike goesvto start blows the fuse ordered another one think new one my be faulty and same thing blowing ten amp and 15 fuses any help would be great thanks
  5. Hi I have a aerox 50 lc 06 I got seconded had in a state and rebuild it up spent a fair bit on panels and bits to get it sorted when getting it running the head lights are dim and when rev brighten up I have had a new battery on and is showing full charge I have put a earth straight from the negative side of the battery to the frame think I may be a earth problem I have a TNT aftermarket headlight on it don't sure if this would cause it sins I got it for my model also my speedo has just gone not sure if this a related problem any help would be great
