madrevs
Everything posted by madrevs
  1. Have got a funnel with a filter in it so will filter it through later tonight and see what turns up in the gauze.its a dark grey colour.as the bike is still running spot on can I flush it a few times with fresh oil and then carry on using it as I dont know alot about strippibg bottom half of engine
  2. Didnt see any bike still runs spot on no knasty knocks or rattles god knows when oil was last changed its a bit concerning though.does oil go a grey colour when old
  3. Drained the gearbox oil today out of my dtr125 after riding it home from work and the oil thsts come out was grey is this normal or should I be worried dont know the last time it was changed.thanks oh and bike runs and rides spot on other than the tick over issue but thats sorted just waiting for bits
  4. Also neutral switch doesnt work have changed bulb bit still no light
  5. Have just fitted a new battery to my 2003 dtr125 as old one was completley dead now my indicators flash really fast.they all work but are flashing really quick would this be the flasher relay at fault and if so does anyone no where it is Thanks
  6. Thanks turning out to be a bit of project but it only owes me 400 quid so its worth spending a few pennies on
  7. On and fix a oil leak comibg fron where the rev gauge cable goes into engine
  8. Hi new to the forum just purchased a 2003 yanaha dtr125 its a bit rough round the edges but roadworthy this is what ive done to it so far New clutch cable Stripped and cleaned rear caliper was binding Made new rh side powervalve cover as was missing until I can find secondhand replacement New exhaust gasket as was blowing (blowing from rubber connector now). Ordered new mixture screw as old one had snapped and was forced in the hole causing no tickover New sparkplug New battery Repaired clock illumination wiring Things still to do Fix indys as flashing rapidly Fit new mixture screw when it arrives Source and fit standard headlight and fairing (polisport one fitted at the mo but leaves wires exposed and has ba20d bulb fitment) Fit new temp sensor Source andcreplace plastics as current ones are tatty. Find where the blue wire with red stripe plugs into behind headlight Lots to keep me busy lol so will probably need a bit of advice along the way The bike goes like stink abd has the powervalve motor fitted and dep exhaust
  9. madrevs replied to madrevs's topic in Yamaha Workshop
    Just to add I didnt fit the aftermarket front fairing and headlight think its polisport amd will be fitting standard one as wires are on display
  10. madrevs posted a topic in Yamaha Workshop
    Hi new to the forum just bought a yamaha dtr125 2003.over last couple of days have made a new cover for rh side powervalve, new battery, soldered wore backnon temp sender, replaced clock bulbs, stripped and cleaned rear caliper as was binding occasionally and a new clutch cable and mixture screw (on order from yamaha).bike is now roadworthy but have a problem with the rev gauge and temp gauge lights speedo side works fine.turning the lights on and only speedo side iluminates and when switched to high beam the rev gauge lights up.neutral light doesnt come on either and the indicators flash rapidly.anyone got any suggestions removed fairing and headlight other day (aftermarket not origional) and there is a blue and red wire which has come unplugged but cant find what it plugs into. Thanks
