gavstaa
  1. ok thank you for your reply slice any ideas where I can get a manual as it I an old dt with drum front and back, just took the front sprocket cover off to find that there is a pipe above the sprocket thats where the milky substance is coming from im not sure if its meant to drip on to the spricket or not.
  2. hi all im Gav im new to this and fairly new to the bike scene, I have a yamaha dt 125 would say between 1990 & 1998 not to sure, but I have. few questionsthatI cant work out myself 1st, the bike hasnt been run in a while and I fitted a new carb to it today had just got it started when I noticed there was a milky brown liquid dripping from around the gearbok area aby ideas? 2nd the 2 stroke tank is under the seat and connected to it is another tank which I think is coolant bu thad no pipes connected so does it need connecting to something? as there is already a radiator on the front with water in. 3rd after fitting the new carb I noticed 2 clear tubes coming off the bottom of the carb but couldn'tfind what they connect to, 4th the throttle got stuck on when I started it and revved the nuts off it as it doesmt have a cut off switch so turned the peteol off and had to wait.for it to stop think its needs lubricating a bit, any help welcome thanks everyone
