Mattblfc8
Everything posted by Mattblfc8
  1. Yh I've put a new spark plug in it could a dodgy battery cause some problems or not
  2. Ok mate thanks I'll try that later is a crankcase seal an easy job to do
  3. Bogs on just part throttle and I'm not sure only had the bike 2 weeks the air filter looks pretty new and yh it does rev high and then drop unless I rev it abit
  4. My 2002 dt 125 seems to bog before it revs and doesn't like to idle on its own sometimes the revs drop and then the bike just cuts out is this a carb issue as I'm not to sure
  5. Yeah going to do it tomorrow hopefully it's ok after that getting annoyed with it now
  6. Yh I will do you think could be dirt or gunk in the carb making it idle badly sorry to keep on but I'm not to sure
  7. The rad level has been dropping and yh I haven't had it long and the bloke I got it off said he didn't use it much and I only use it for short journeys aswell so that could be the problem would the coolant in the exhaust make it smoke a lot for a bit and Also it doesn't idle very well and even when warm is hard to start without the choke
  8. Ok mate hopefully just case of new gasket thanks
  9. Can anyone guess at what the problem could be on my dt 125 2002 I thought it would be the water pump seal so I've got a new one ready to fit but now I've found coolant in the exhaust so could this be just the head gasket or something worse I have a new head and base gasket just in case thanks for any help
  10. Hi can anyone help explain to me in brief how to change water pump seal and has the side casing and 2 stroke pump all got to come off thanks
  11. Thanks for replies do I just pour that into gearbox and let the bike warm up for a bit and then just drain it out and put fresh oil in
  12. Hi thanks for reply and no I haven't tried one was just wondering as I'd like a new exhaust on mine as I've got the standard one it's had the restrictor took out but I think it's still got the restrictors in the main part and I don't really wanna cut it open to get them out but my bike sounds like a bit of a toy at the moment want a bit more of a louder deep noise if not I'll have to save some penny's for a dep or big one
  13. Hi guys I was wondering if there was a way to flush out my gearbox after having creamy oil from water pump seal being faulty I don't want to fix it all and put fresh oil just for any junk that's left in there to ruin it again any help appreciated
  14. Hi my names Matt I've just recently sold my car to buy a dtr 125 2002 for commute to work and just more fun looking for some help and guidance on some things and to see what others have done to there bikes
  15. Hi my names Matt first post hope I'm doing it right any input will be appreciated I was just wondering if a yz exhaust would fit my 2002 dt 125 or could it be modified to fit thanks
  16. Does any one if a yz exhaust will fit a dtr 2002 or can they be modified in anyway
