nigel smith
Everything posted by nigel smith
  1. Thanks mike and paul for the advice, Well i have woken up today with full on MAN FLU so wont be going outside today, i feel like ( i think the medical term is) SHITE!!!! cheers nige
  2. I think they are standard, i think ba9 type not LED or the likes thanks by the way
  3. Hi all The DT125X 2005 i have has hazard warning lights, I have a slight problem when switched on they flash once then nothing the indicator light on the dash stays on. My indicators when switched on left and right work fine. I can only find one indicator relay on the drawings. Does anyone have any ideas ?? Also as they are fitted are they part of the M.O.T ?? Any advice would be very welcome. cheers nige
  4. tig welder mmmmmm niceee
  5. Hi all Well i got back from a day at my parents earlier than i thought with an hour of daylight to spare so i whipped my front wheel off. i drilled the rim of the hub with a 1.9mm bit and knocked in a 2mm roll pin leaving in about 2mm proud and jobs a good'un. speedo works perfectly. thanks everybody for there help!!! and a big thank you to paul (airhead) for offering to come round and help. cheers all nigel
  6. Hi scott i did my CBT at 45 your never to old !!! nigel
  7. hi the clutch when the cover was first removed looks like one of my wifes failed attempts at making a meat pie
  8. no worries kev
  9. cheers paul thats great and yes i still have the same number
  10. hi paul Thats great but gonna have to put you off as the wheels back on and im using the bike for work, Maybe if you have a spare ten mins at the weekend? cheers nige
  11. hi there the proper part is a new hub/wheel and even second hand your talking a £100 hence looking for advice on a repair cheers nigel
  12. our thoughts are with you but remember the good memories will grow old with you
  13. Hi all i need some advice!!! I have discovered the cause of my speedo being intermittent. On the DT125X there is a single lug on the hub to drive the speedo gear and guess what mine is missing. i have been getting some movement due to the speedo drive gear rubbing against the hub as the tabs on the drive gear look a little worn. first pic is my hub no lug second pic is how it should be my question is do you think it would be possable to drill the hub and insert a pin. the pin would only be driving the speedo gear so should not be under a lot of strain. any ideas would be great thanks nigel
  14. hello there there a great bunch on here and very helpfull yambits is good for older models but i often use https://www.motorcyclespareparts.eu/ takes a couple of days longer delivery but prices are pretty good. cheers nigel
  15. hi slice no nothing is working the mileage is not moving. cheers nigel
  16. hi paul i have taken the cable off the back of the speedo and spun the front wheel and the speedo end of the cable turns. i will have another look maybe the cable end in not locating properly in the speedo. while your about paul do you know if you grease a sprag/starter clutch ? i have to change mine and wanted to know if is should be lubricated ?
  17. PS if anyone has one for sale i would be very interested
  18. Hi all has anyone tried to repair this type of speedo? the cable seems fine the drive is working. The needle is not moving and the milage is not moving, any ideas would be gratefully received cheers nigel
  19. thanks for the info mr slice
  20. The seat and tank do look older but im no expert, As for the starter motor you can always run the heavy cable from the motor directly to the battery to see if you get any movement. you can buy brushes for the motor but not much else, https://www.motorcyclespareparts.eu/yamaha-parts/motorcycles/dt125x-2006/starting-motor-353958.aspx i have had parts from this site and prices are not to bad, hope this helps nige
  21. second hand ones are hard to find, if you need one try searching for a gilera 125 sc same engine and often cheaper
  22. Hi Not sure about Suttons Yamaha Europe parts list tells you your bike from the vin. could have a later engine fitted. nige Think the first electric start in uk was the dt125re 2004 when they work there great when they go wrong its lots of pounds your talking £250 for a new yamaha starter motor.
  23. hi all what is best for an aluminum engine traditional ethylene glycol or silicate? and can one of you lovely people explain what silicate is ? cheers nigel
  24. hi there Do you have a multimeter ? if so check the voltage out of the starter relay the heavy wire to the starter motor. when you press the start button you should have twelve volts going to the starter motor. if you do then either the starter motor is kaput or as the bike has stood for so long something could be seized. have you tried turning the engine over by hand? cheers nigel ps i did not think they added the electric start until the 2000s
