chrism
Everything posted by chrism
  1. Hi can any advise i am having major issues with starting my 2008 YBR2008. turn the key the electric start, fuel pump primes and tuns over without firing. it flashes 1 long and 9 short flashes on the engine managment light. This morning it did not want to start fired a few times and cut out then fired and run. got into work an it wnot stat at all. any suggestion to the engine falt code and potential issues. i have replaced the plug with no change. thanks for the advice regards chris
  2. Hi Guys Just a hello prior to picking you brains. Just starting out on my biking adventure a little late in life (45) only wishing i done it earlier. look forward to getting all that good info from you all. good luck and regards chris
  3. Can any one help I have a 2008 YBR125 with start problems it start but won't fire. The engine managment light flases one long flash followed by 9 short. This is a intermittent problem but is a bit of a pain. I have replaced the plug and air filter. Any know what the falt code for the above!! regards chris
