Dt rich
Everything posted by Dt rich
  1. Hey no I haven't changed the pick up as its fairly new any way I have wiggled all the wires and put a new ignition on I'm pretty sure it's electrical problem aswell ill try another pick up when te rain goes away. I have checked wireing it is in a bit if a mess but no wires broke or pinched except a brown one that goes in To the headlight not to clued up with elecs tho but I see that broken before It started this problem. And I did not think the power valve would corse that much trouble as only moving about a mil or 2 thanks for clearing that up To put a feeling to it feels like your running with the choke on (which I'm not)
  2. Nope no oil or anything else leaking its all lined up properly aswell ill try get it on a video later and post it
  3. It is pinned open but pushes out I mean literally pushes out of the side of the barrel only a tiny bit but only does it when it is bogging out ad I want to set it up but I need the little plastic pulley that goes on the end of the power valve then I can do it got servo cover cables and all wires are on the bike
  4. No worrys if you get any luck let me know please same as I will let you know
  5. Hey glad to see I'm not te only one with this problem And I've read that post about ten times now don't really help me to much thanks tho It might be going to a shop tomoro if I can get a deal on some cheaper labour if it does ill post what the problem was if they find it (don't like paying labour but run out of things to check) I have tried a different magneto as got 2 spare bottom ends and still done same thing so don't waste your money just yet as I still think its some thing simple
  6. Could the power valve make the bike do what it's doing? As the power valve pushes out of the barrel only by couple of mil but were I haven't got the servo it should not be moving at all?????
  7. Was not the jet tried a 210 and done exactly same thing :s
  8. Okay I will try that today was running fine with 240 before this started and I knew from the smell the heat to touch and temp gage nearly on red usay sits just off of cold. I see what your saying about bogging motor as took petrol tank off yesterday started bike and it was ticking over for like ten minutes with no petrol tank has never done it for that long before Thank you for your help ill keep you posted and have a read on your spark plug and temp post
  9. Standard is 210 and runs rather hot so put a 240 in it which runs lovely spark plug a nice brown colour Think in going to have to pay some labour as I'm not getting any where I'm tinkering on it all day every day
  10. Still stumped new carb new coil new spark plug cap new reeds new ignition new plug checked exhaust Any one in Kent fancy a bacon sarnie and brew all day haha
  11. Yer I no I am in process of doing the power valve servo just need the pulley got everything else and I live on long straight roads so usually higher up in the revs so it dont bother me no bottom end and yer I have had a look at the expansion chamber looked pretty clean but did not look in silencer could that course this problem it's got a full dep sytem on it Thanks so much for your replys
  12. Yep had carb off and been soaked in carb cleaner and sprayed compressed air through all jets and passages air filter is clean no air leaks and I have played about with air screw no luck there have gone all the way to 2 and half turns out then back in to 1 and half turns were it runs its best I'm completely stumped now when it misses the power valve pushes out a little bit if that makes sense don't no if it is meant to to that (no servo fitted just pinned open) also tried another carb did not make a difference That's why I think it is electrical :s On another note if any ones got the pulley for the power valve for sale pm me please
  13. Nope the power valve was only part of the problem any one else got any ideas I cleaned the tank and Petcock all looks to be working fine
  14. I think I have found the problem thepower valve had moved and was bouncing in and out just a bit of fine tuning
  15. Thanks for your reply I will have a look at that today it is so strange here is a link not my video but exact same problem http://m.youtube.com/watch?v=FRy6i2PnUkk
  16. Hey all I have got a dt 125 r 1996 when riding it will not go over 6k sometimes a little bit more just sounds like it is losing the spark every now and then but is fine all revs up to 6k it does it in neutral but allows me to get to 8k I have recently done crank seals and it run fine after that so checked all magneto an stator they all look fine I'm very stumped now can any one help There is a video on you tube showing what I mean. Ill post the link soon I have changed spark plug Cleaned the carb New coil and lead Checked all wires for wear If any one can help would be much appreciated
  17. Hey all I have got a dt 125 r 1996 when riding it will not go over 6k sometimes a little bit more just sounds like it is losing the spark every now and then but is fine all revs up to 6k it does it in neutral but allows me to get to 8k I have recently done crank seals and it run fine after that so checked all magneto an stator they all look fine I'm very stumped now can any one help There is a video on you tube showing what I mean. Ill post the link soon I have changed spark plug Cleaned the carb New coil and lead Checked all wires for wear If any one can help would be much appreciated
  18. Hey all thanks in advance for your help I have a dt 125 r 1996 was running fine got stuck in some traffic pulled away power band just kicked in and it started spluttering had cleaned the carb and thy never sorted it but i realised my throttle needle was bent could tho e the problem any help much appreciated cheers Hope I posted this in the right section of the website
  19. Had to go on the proper site to do it but is done now thanks
  20. Yes that could be interesting allways cars meeting up never see many bikes meet up in Kent And okay thank you I will have a look now cheers
  21. Hey thanks, and I am from sheppey were abouts are you? Any one know how to put a profile picture up on mobile site can not find it any were thanks in advance
  22. Hey thanks for the welcome
  23. Hey all Got told I have to post here first My names rich I ride a dt 125 r 1996. Been into bikes since I was a little kid. This is first time in a forum so much help is in here, and I can offer some help too thank you to every one who does share there knowledge. Any one in Kent wants to go green laneing let me no I'm up for a cruise I want to try te Maidstone green lanes if any one goes there?
  24. Sorry for late reply been busy and sorry I am on my phone so getting use to website did not no there was intro bit will find it and post in there. Checked crank seal an you was right so replaced that and haven't had a problem since except magneto fell off after i had done it to specific tightness (from haynes) so rang motorbike shop they said yamaha thread lock it at the factory done that touch wood no problems
