fil77
Everything posted by fil77
  1. I thought that they only started to put fuels gauges on bikes when they went to fuel injection because they don't like running dry. All carburettor fed bikes that I have owned, including my present XVS650, have never had a gauge only a reserve fuel supply.
  2. As far as I know there is no difference between a Dragstar and a Vstar models just a name change. I beleive the year that things changed was 2004 but not certain. I don't think there was much that changed. I think it was mostly due to emmission control. Exhausts and probably AIS. The main differences are between the Classic and Custom and they are cosmetic.
  3. Hi! Chris, Welcome, I am 6'1" and I have no problem comfortably riding my Classic. My son also has one and his sits for months and still starts easily, no charging the battery. I don't think this will be good for battery life in the long term but a can easily sit for a few weeks and will not cause an issue. I love mine and out here an XVS650 costs $12000 on the road new where as the Harley's are around $29000. An awful lot to pay for a little extra power and a name. I don't know what distances, road conditions, or traffic is like in England but I feel the XVS650 is an excellent and reliable commuter for me.
  4. Here's another set of figures for a 2010 XVS650 Classic. Over the passed couple of years I have kept records and averaged 5 L/100K or aprox 56MPG (imperial) mainly country town riding (60KPH or 35MPH). That gives me an average 240K's before I switch to reserve (Aprox 150 miles). If I ride like a grandma then I get better ecconomy but if I try to ride like Joge Lorenzo then I expect less ecconomy.
  5. I think the rider is as big a danger as the car driver. Slows down just after overtaking the car in the left lane to start the road rage. Wanders all over the lane and when accellerating away wanders accross the centre lane and back. The old saying of "People in glass houses", I reccon, applies here.
  6. The problems you describe seem to appear often in forums I have read. It appears to be common with Yamaha V twins. There is a modified clutch lever for the V-Star range which some riders in the US swear by. (The Clever Lever) The accelerator touchyness has also been mentioned but I don't recall any fix for that apart from a larger diameter after market grips. I found my XVS650 a little that way on both accounts but after putting on a number of kilometers I am used to it and don't like the idea of the mods. I have been riding for years and all bikes have their own idiosyncrasies to contend with.
  7. From what I have seen there was a change to exhausts around 2004-2006. Catalytic converters were added to the mufflers and a slight change in the header pipe length also. Don't know how valid this is or if it would cause a problem.
  8. Check the earth connection to the tail assy.
  9. If it was me I'd just get a new battery. It sounds like it has had it. Doing a capacity check properly is a lot of mucking around and takes time. If it is 8.6 volts with ignition on then it is flat and not capable of turning the motor over enough and the voltage would be much lower whilst the starter is activated. Not enough power left for the ignition to spark sufficiently. 11.6 volts when the motor is running is also a bit low but a dead battery can also cause that also the alternator will not put out a lot of power at idle so voltage will be down then also. It should be more like 13.5 volts with a good battery and a few revs. It should stay fairly constant above idle. If you charge that battery then test its voltage you may see it up around 13 volts with no load for a short time after but if it is dead it will not hold it and will drop with a load such as the ignition.
  10. The battery you have will crank the bike just fine. The difference between 5 and 6 amp means nothing but if it is Amps per hour (AH) it just means the 5AH will go flat quicker. It is the voltage that determines how fast it will crank the motor and the capacity determines for how long. From what I see the LB5LB is a standard wet cell where as the YTX7L-BS is a sealed AGM type. Both will work but the wet cell needs looking after, water level topping up from time to time and prone to leaking acid. Most bikes now use saeled batteries for safety and low maintenance. The LB5LB will probably die earlier as it's Cold cranking amps (CCA) will probably also be lower causing more deteriation each time you use it to start.
  11. Welcome from a fellow Novocastrian! Difference is my Newcastle is on a different river to yours.
  12. fil77 replied to neversaydie's topic in General
    Merry Xmas from the colonies.
  13. Don't expect to see DC voltage at the headlight. It should be AC and vary considerably with revs.
  14. Like I said I see nothing wrong with your electrics. There is no regulator so voltage will depend on revs and current drawn. If the battery is charged, very little current will be drawn and voltage will be around 7.2 to 7.5 volts. Depending on your meter and range you could read anything from 7 to 8 volts. Put the same rated globe back in and things should be fine.
  15. Could be a restriction in the tank venting system. XVS bikes don't vent at the cap but have a tube running down the frame. If this gets bent, squashed etc it can cause similar symptoms to what you you describe. Don't know how the Virago is setup.
  16. As usual with 6v systems and looking at the wiring diagram, it appears that there is no regulator for the DC on an RXS100. The battery does that itself. This is not good for battery life but you need to keep a check on the acid level. The head lights, tail lights and instrument lights are all run direct from the alternator. You will notice they do not work unless the engine is running. Indicators, neurtral light, and horn need DC so run from the battery. The system is pretty much balanced so if you change the wattage of any light or add some electrical device you will upset that balance and thae electrics will not work as they should. The headlight did blow a bit too regular on my previous bikes as the voltage was up and down depending on revs. Batteries did not last long as I rarely checked them.
  17. Hi! Fellow Aussie.
  18. fil77 replied to Roast's topic in New Members Welcome Area
    Yes Roast I was much younger then but except for the aches and pains I still feel the same. Singapore used to send an attachment out here for bombing practice. We often had many of the crews here for a get together where our friends and us could feed them with good ole asian style food instead of the Aussie stuff in the mess. Had some great times and fond memories. My kids used to collect aluminium cans and cash them in for some pocket money till one day I found out that the cans from Singapore were infact made from steel. We were ripping of the local aluminium recyclers.
  19. fil77 replied to Roast's topic in New Members Welcome Area
    Yes Mike it was the RAAF and stationd in Butterworth from 1969 to 1972. Married my wife there in 1971. I have never been to Perth, it is about 4 hours by plane or a couple of days by car or train. I hope your son enjoys Aus.
  20. fil77 replied to Roast's topic in New Members Welcome Area
    Sorry Mike1949, I was in a different service. I spent 3 months at Tengah Air Base on detachment as our home base was getting it's landing strip resurfaced. That was in early 69. I spent 3 years at Butterworth in Malaysia and had a few trips to Singapore. I have no idea about the happenings of the navy. I do recall a big USA carrier payed a visit when we were there. I think it was the "USS Enterprise". A few of the mates got to go aboard but I was not a drinker so did not get to the bars enough to be invited. The good ole days
  21. fil77 replied to Roast's topic in New Members Welcome Area
    That sounds like ,what I know as "The Tiger Balm Gardens". (Probably not the correct name).
  22. Hi! fellow Aussie from Newcastle, NSW.
  23. fil77 replied to Roast's topic in New Members Welcome Area
    Hi! Roast Singapore and especially Malaysia are my 2 favourite places to be. I married my wife in Butterworth 42 years ago so my inlaws are all in Malaysia. I have a great time every visit and love the food. Spent a few months at the RAF base at Tengah back in 1969. Things have certainly changed since then. I hardly recognised it when we were there a few years ago. My nephew who lives in Johor and works on Singapore took us over for the day. Happy and safe riding. Ken
  24. Hi! Pete
  25. fil77 replied to joe.b's topic in New Members Welcome Area
    Hi! Joe,
