Tom125mx
  1. in some european countries the nice small rear light was standard... I'm wondering what the swiss MOT testers will say.. ;-)
  2. last cosmetics done on the dt 400(e.g. decals)... consider to reactive the oilpump. this weekend I'll start to work on the yellow dt 250. look will stay "used" - only technique/electrics/mechanics will be renewed/restored.. cheers tom
  3. magic carpet? .. sure!! .. nothing less ..
  4. the 125mx... the garage is full.. ;-)
  5. thx for the comments and the spellcheck ;-) @blackhat250: my dt125 IS a monoshock mx. it's not visible on the photo.. I'll take another photo next time to show the whole "family" )) cheers tom
  6. so... just created a photobucket account which is tested here ;-) finished recently: a dt 125 mx currently working on the dt 400 mx just started: 2 dt 250 type 512 .. (hope the photo-upload worked..) cheers tom
  7. how can I remove the cables without opening that box??? the cable connector is inside!? and: since the oilpump is disconnected anyway: it might be the best solution to go with a single cable anyway.. do you agree? where do I find a descriptio how to upload photos? it does not appear intuitive or selfexplantory to me ;-) tom
  8. idea is to oil/grease the whole throttlecable system to make it moove smooth enough .....
  9. yes. cylindrical... will i have to take the cable off the carb and the pump before the cylinder can be opened? tom
  10. my dt 400mx is extremely load, althought everything looks ok and original... i'm wondering what the mot-testers will say.. ;-) is the dt400 known to be that load? tom
  11. hi experts! does anyone know how the "black box" in which the throttle cable under the petrol tank is divided into the two cables for the carb and the oilpump? it cannot be very complicated, but it refuses to open.. grrrr. thx in advance tom p.s. i'm currently restoring a 1977 dt 400mx (almost finished) and a 1976 dt 250 type 512 ((just started)
  12. Tom125mx replied to Tom125mx's topic in Classics
    Sorry, the moderator cut off the second half of my post, because I was asking for frame/documents for a 76 dt 400, but did not use the Wanted section... ;-). The Problem has been solved in the meantime. The bike is from Austria... Once I have the bike in my Garage I'll take pictures. (When everything works as planned, I'll get the 77 mx first, gehen the 76 twinshock..) Cheers Tom
  13. Tom125mx posted a topic in Classics
    Hi all, I recently purchased 2 1976 dt 400. Edit by DDT: Wanted items in the wanted section please.
  14. Just to close this discussion: ROOT CAUSE WAS THE BOWL GASKET, Repaired it and now it fires on the first kick!! Thx for your help! Tom
  15. hi, while working on some electrical issues (flasher is not working any more; battery is not charged correctly) I found the rectifier that is mounted underneath the fueltank more or less molten down .... (where a double white lead meets a red one...) the rectifier itself is a black littel box of about 2cm) do you know from where I can get that part? is it yamahaspecific or can I use a generic one . .. hope that this is the root cause of my probs... cheers tom
