melvynford
Everything posted by melvynford
  1. Hi guys just checked the valve clearances on my XJ600. # 1,2,3. Inlet are 0.09 to 0.10.mm #3 Exhaust is 0.30mm. I need two 2.60mm 1x 2.70mm 1x 2.75mm The Shims are 25mm wide. Tried eBay but no joy. Dose anybody know a good site where I could get the shims. Cheers Mel.
  2. Ha ha very good man. Thanks for the info.
  3. Hi guys . Need a bit of advice. Have a 2000 xj600. When I go out on the bike if I hit a grove in the road our where they have been doing road works. The bike twitches on me . I have put new rear wheel bearing in and new spindle. I have put new steering head bearings in . Had the bike up on the Main stand grab the swing arm to check for any free play and it is ok. I can't think wat it is but it is dangerous if I am going at high speed and hit a grove in the road. Can anyone advise Regards Mel.
  4. Hi Guys . Gogleed the part number for the rings . Got a site called Partzilla . Got the rings for 30.15 dollars which works out about £18.00 So just went ahead and 4 Sets . So when I rebuild the engine it will have new rings. Happy days can't wait to get the twat back on the road. Mel
  5. Ok Cheers Bud. Will google the part number and see what comes up.
  6. HI Preload. After Honing the liner it is measuring 59mm.The original Bore dia was 58.505 to 58.545. After checking the ring gaps they are outside the maximum dia. So will have to fit over sized rings. Have tried EBay but no joy.
  7. Cheers Pal. Tried EBay .don't have them for my model.
  8. Hi Guys. Pulled the engine on my XJ600. Stripped it down only to find one of the cylinder liners was scored inside . Honed the liner now spot on. Phoned Yamaha and they are Quoting £40.50 for a set of piston rings . Dose anybody know where to get aftermarket piston rings . Cheers Mel.
  9. Name: Yamaha XJ600 S Diversion (2000) Date Added: 16 October 2013 - 04:20 PM Owner: melvynford Short Description: None Provided View Vehicle
  10. Hi Guys. As it turned out the ignition coils where both all right . I got them re tested. Left the bike into a proper bike shop while I was away. It turned out to be the throttle position sensor and the CDI Unit. The shop is testing a spare CDI Unit tomorrow to confirm if mine is fecked. Will keep you Posted on the outcome Mel.
  11. Hi Guys thanks for the info .But I am going away this morning with work for a month so the bike will have to wait till I get back home. Yep both coils are kaput I took them to a garage and he got the same outcome as me. Just me fecking luck. Cheers Mel
  12. Hi Slice. It looks like I will have to pay £216 for two coils. Was looking through ebay spare parts. I think I could get a second hand pair of coils at a good price but are they of a good dealer. Then how long will they last for. Now I know why these cunts are stealing bikes for the spares because there is big money in it. Its a lot of money to fork out. But if I buy them from Yamaha I know they will last.
  13. Hi DirtyDT thanks for the info u where spot on about the ignition coils. Pulled both coils off and tested them with the Multi meter. Both coils fucked. Priced new ones only £108 each fuck me I was not expecting that price. One thing about the XJ6 nice bike but the parts are expensive. Cheers Mel
  14. Hi DirtyDT thanks for the info about the coils. Checked the Starter relay / Starter cut off relay as per the Manual but they are working fine. I will check the coils . Mel.
  15. Hi all. Pulled the plugs one at a time no spark on any of the plugs . So have come to the conclusion it is an electrical fault would explain why the bike cut out on me . According to the Manual it could be the Starter Relay. Will check it out . The more I think of it Definitely an electrical problem .Will just have to go through a process of elimination to sort it out. Mel
  16. Right here is one for u .Monday morning took the bike out of the garage started first time on the choke great. Rode around most of the day as it was great bike weather. Tuesday did the same again only sitting at traffic lights the twat stops had to push it to the side of the road talk about being embarrassed. After a few pushes on the electric start it fired up so of we go again all fine. Then this morning brought it out of the garage fired it up drove to the house to get the gear on went out and the C--- wound not start .Now there is Petrol in the tank. Pulled plugs bit wet so dried them off. Plugs back in. Plenty of charge in the battery but this C--- will not start . U can see the fuel in the filter. The only other thing I can think of is to pull the plugs out one at a time and connect it to the ht lead and turn it over to see if the plugs are sparking. Failing this I am stumped. Had a look through the manual but if u read it u would have half the bike stripped to find out what is wrong with it The bike in question is an 2000 xj600 Diversion has anybody had the same problem. Any info would be great. Mel
  17. Hi Slice thanks for the info. Turned the clutch boss over and was able to get at the bolt with a small drill without damaging to the thread. Low and behold I got the blighter out with a small screw driver
  18. Hi can anyone tell me the Torque setting for the clutch pressure plate bolts on a xj600s Diversion year 200. I bought a manual and it says 8Nm .I Torqued said bolts to this setting and broke a fecking bolt. Now the end of the bolt is stuck inside the clutch boss. Any info would help.
