Bobstar950
  1. Don't know if this has been mention on here before but there is a fairly simple solution to this. Undo the 3 100m nuts. Lift the back of the board and shim it out by a couple of millimetres (between the board and the hanger rear of the top nut). Tighten the nuts, being careful to not over-tighten. Think it heightens the back by about 15mm. Did this and I didn't scrape the boards once, even though I was riding with a passenger. BTW. nothing wrong with sticking the pre-load to the top. It doesn't affect the stiffness noticeably, just the ride height.
  2. Hi new to the 950 but have had customs before. On the subject of screen. I got a quick release with my bike, not being a lover of them its on Ebay at the moment. But to my point, if buffeting is a problem there are small adjustable deflectors you can fit at the top of the screen that allow you to get better airflow. Second question. My footboard seem to close. I have looked at the extenders you can buy and seems to me you could do it yourself pretty easy. Was thinking along the lines of taking the boards off at the bolts on the frame and making a template with ply so I can simply position it where I want and drill easy. Then using this to make steel plates. Would it be that easy (shifting rod and brake pipes aside)
