Simo
Everything posted by Simo
  1. I Should also add when i got the spark back and run the engine it would only run with the choke on so i was suspecting an air leak so a new air filter, clean/reconditioned the carbi put some sealant on all surfaces round reeds, manifold, carbi now runs fine and idles fine revs quite nicely better than before i think but have only idle / run the engine in shed like i said first ride tomorrow hopeing all goes well the muffler tip needs fixing doing this in the morning but was curious what diffence it would make to replace the stock exhaust with a compresion chamber - baffle... ? i imagine it would interfer or stuff the engine's preformance.... or maybe blow up the engine lol but was curious if it would have any benifit if any thanks again -Simo
  2. Well I feel stuid lol after checking it 3 times with the young fella and explaining everything as we checked it all ......the screw in the points was loose so it wasn't set/opening and a bad earth (Severed earth lead) hmmmm ohwell fixed now and running again first ride tomorrow see how it goes and a tune up then back to wiring all the accessories Thanks Again For All The Help -Simo
  3. so took the casing off and looking through the holes/windows on the flywheel looking at the points while the bike is kicked over there's deffinatly no spark atall and they don't actualy look as if they open atall always seem to be shut cant visualy see them open atall but im off to work now so ill pull the flywheel off and examine the points / condenser when i get home see what i can work out, might need new points Thanks again -Simo
  4. ok thanks i'll check that and let you know what i find out have had the flywheel off and cleaned all the area but didn't actualy check the points only cleaned them will rip out the multimeter and test the condenser and check the points thanks again for your reply -Simo
  5. Simo replied to Simo's topic in New Members Welcome Area
    yea all my other bikes are older ones too from 71 to 97 best one would be my yz86 followed by 84kx
  6. Simo replied to Simo's topic in New Members Welcome Area
    yeah i was a member of a group on facebook but after asking the same question for a few weeks and all you get is "OH A 175 HE SAYS ....AN AG HE SAYS HAHAHA buy a bike from this century bro".... i mean realy c'mon if they are not going to reply nicely or with something informative to say why bother... anyways i got sick of it there so im here now -Simo
  7. Simo replied to Simo's topic in New Members Welcome Area
    so been checking out some forums this one looked the go ... seems like alot of the help questions get answered or helped pretty well and havn't seen asmuch bi**hing as everywhere else it's good Simo
  8. Simo replied to Simo's topic in New Members Welcome Area
    ohhh needed some help with a bike i just got recently a 175 AG bout a 73 74 model roughly i think was going fine now its not so i chucked up a post over in your yamaha classic section i hope is the right area
  9. hi all i'll up-date this post with pics and more info tomorrow if needed i recently recieved a 175 Ag Bike 70 - 80 model road trail when i got it was running fine... wires are running everywhere has been cut and shut a bit by the looks of it (the wiring loom that is) but non the less went well for 3 days no accessories worked atall , horn, light, brake light, etc... the key did turn the motor off and so did the kill switch... with the wires everywhere didnt want to touch it so left it at that until now no spark atall so i have no spark have been trying the multimeter on it most of the day cant work it out wondering basicly is there a way i can take off the wiring loom and leave just the 4 wires from magneto and rewire them myself and if it goes i can rewire the rest or order a wiring loom etc... surely someone can head me on the right path if i use the multimeter on the sparkplug and to the head i get a reading of 35 - 50 Volts yet no spark if i turn off the key or kill switch i get no reading so im pretty sure it isn't them and its possibly from magneto -- ignition coil -- spark plug have tryed the plug on another bike sparks fine and tryed a different plug if anyone can point me in the right direction as to where to test on the bike and a rough voltage i should/shouldn't get so i can isolate the problem a little easier will also add it did have a battery in the loom originaly but it has been taken out and some of the wires moved or cut cant completely tell any help appreciated thanks in advance Simo
  10. hello all im new
