overpl
Everything posted by overpl
  1. Well, thanks anyway for answer:) At german sites they are expensive:/ for german guys 100euro is like for me 100 PLN, but 100euro = over 400 PLN ;] so I really can't afford it right now;) Cheers.
  2. Does any one have a spare ignitor unit for XS 400 dohc 12E? more precisely I need TID 12-07 12R version. I'm a poor guy so if you have it I will be greatful to buy it for symbolic price:) or send you back some other parts. EDIT: Maxim version is the same as XS 400 DOHC 12E one.
  3. Hi, I have a real trouble with my XS400 DOHC. At first when I bought it, PO said that she smokes like 7liters/100km So what I've done: - eliminate hole at muffler - new jets to carbs (stock) - change oil, checked air filter- fine, - set valve clearance - changed float height to about 20 mm - (was about 16'ish) I haven't have a chance to check consumption before that, but suddenly I had sth like 10 liters/100km so I've changed float height to about 22mm - it is almost far as can be, and manualy pull out the choke lever in carbs (when I was pulling choke my XS couldn't even run - just drown right away, after setting higher float height it started to work, but still poorly - RPM at choke about 1500-1700 - when idle 1300) - seems that my choke couldn't fully close with choke lever at bar. Now I have my consumption at about 7l/100km, and about 5.7 at large distans constant speed 80-90kph. So it is totaly abnormal and high. I don't know honestly what I can do.. engine sounds fine besides that I have a feeling like its drowning specialy at RPM like 3000'ish-3500. Sometimes when I maintain constant speed ex. 60kph I have a feeling that my XS loosing power from time to time. Also when I shift down gears with throttle on ( I don't know how to name it in English) there is sometimes no reaction to my open throttle... So what I can do to make my consumption lower - cuz it supposed to be sth like 5liters/100km or less. Kind regards, Over.
