51st state
Everything posted by 51st state
  1. thanks for the replies, i understand that the endr and ntrd are the R and X models with different wheels sizes , the battery connection seems fine as the starter starts the bike easily, i have also checked the connections to the back of the speedo which are clean and tidy , i have also done some tests with a multimeter to the connection and have found it has a permanent 12v feed even when turned off and is somehow linked to the neutral light, if i unplug the neutral light sensor the bike will not run so it also cuts the spark , any ideas? i've also tested for ohm readings and volt reading on the dash connectors while using indicators , main beam etc and found that the readings change so feed to the dash looks to be working correctly and pointing towards a faulty dash?? i will phone a dealer and see what they have to say about the 36-05 that flashes up, my guess is they will ant me to take it in and collect some money! there are some good after market lcd clocks on the internet at very prices Pritchard XT what problems have you found with loom? all info appreciated cheers H
  2. nobody got any answers ? have seen the thread by "grouch" and his cursed xt125 any help would be appreciated cheers H
  3. 2008 xt125r , neutral light stays and dash also flashs up "endr" and "ntord" when ignition is off, when ignition is turned on the neutral light gets brighter and dash goes off, have tried all solution of diconnecting battery and then turning on when "endr" flashes up while pressing "mode" button on left switchgear but still the same! i have noticed the neutral light is dimmer when ignition is off, if i put it in gear the light goes out and the dash stops showing endr and ntord, is this a wiring/earth problem? has anyone solved this? or is it just the dash problem?? another thing it does if left diconnected for an hour , when i reconnect the dash all the numbers etc light up on the dash like a system test so lcd screen must be ok, it then shows RD 35-06 before showing "endr" and "ntord" any idea what RD 35-06 means??
