Everything posted by fakhir
YB100 Restore : 1980 model (100cc) :)
Finally got the engine separated from the bike frame. Putting the engine on a table to make a comfortable work environment. No matter how hard I tried, I was unable to get this annoying little kick assembly off the engine: Closeup of the piston area: Another closeup. This is the space where the carb is placed. The rubber tubings have turned into like metal pipes after fighting the natural elements for 10 long years. I had to cut these using a very sharp knife or cutter: Closeup. Check out the deformed screws:
Got a bunch of new tools. Forgot to show off earlier: Feeler gauge, 0.05 mm to 1mm. Vice grip plier. I don't know what these are called: maybe magnet holder and magnet extractor?
Rear break pedal assembly. Closer look at the joint: Bit zoom: Further zoom. The amount of mud and gunk is surprising:
Detached rear wheel assembly. It didn't go off without a fight: Finally detached the engine. To my surprise engine was not that heavy as I thought it would be: Closer look: View from the other side: Zooming in on the rotor wheel: Drive shaft closeup:
Removing cylinder: Cylinder closeup. We will take a look at it in great detail in near future. Moving on to detach the engine from the frame. Before loosening up the main engine assembly bolts, it is a good idea to provide some support from underneath: Cool, air filter assembly is off:
Another look at the head: Zooming in: Further zoom. The surface appears to be covered with salt, fungus and other gunky stuff.
Opening up flywheel nut: Detaching the head. The outside appears to be covered in fungus: Cylinder assembly: Another view:
Getting the drive sprocket off the frame. Attempt 1: Since the bike was in neutral and I was unable to put it in a gear (maybe broken gears, who knows). I tried to jam the wheels with the help of wooden hammer shaft. Bad idea, i know. This method can potentially damage the rims. Another mistake I made that I removed the rear shocks way earlier. Rear wheel assembly proved pretty hard to control. Attempt 2: The correct one. Press the breaks real hard . Furthermore use a long pipe for leverage and the sprocket nut will come off quite easily:
Continuing from previous week, still disassembling the bike. Finally got the exhaust pipe out, was pretty tough job. In this case C-spanner was not effective at all. Too much rust and gunk, the sleeve nut was totally jammed. I then used pipe wrench which did the job: It seems that the drive sprocket washer had witnessed mechanic abuse (molestation or rape might be appropriate words). I had to use hammer and a minus head screwdriver to chisel my way into the washer. This made enough clearance for the socket spanner to comfortably sit on the nut: Closeup view:
This week's updates (5-May-2013) Hi guys, hope all of you are doing great. This weekend I spent a couple of hours on the bike (3-4 hrs max). Succeeded in detaching the engine from frame. Attached pictures show the progress. Enjoy !!!
This is it for now. As I mentioned earlier the updates are probably going to be slow because I am feeling lazy most of the time. Currently I am facing the challenge of detaching exhaust pipe from the cylinder. It appears that it is pretty much jammed in due to rust. I applied WD40 and used C-spanner to open the sleeve nut but totally failed. 2nd challenge I am facing is that the rear breaks appear to be totally malfunctioning. So taking off the drive sprocket is proving to be extremely difficult. As I try to loosen it up the rear wheel starts to spin like crazy. I can't put it in gear because 1) the gear change pedal is off, and 2) gears appeared to be jammed at the very beginning. 3rd challenge: The rotor wheel starts to spin like crazy as soon as I try to take off the big nut in the middle of the wheel: Any ideas ?
Rotor assembly closeup. The rotor wheel also has huge amounts of rust on it: View of the drive sprocket. Some wise zen-master mechanic has already tried to mess it up real bad. You can see the damages on the main nut. Also the area surrounding the gear change spline shaft is full of rust and gunk: Air filter, or what's left of it lol: Another view of the electrical mess:
Taking off crankcase cover and exposing the rotor/generator assembly: Closer look at the crankcase cover. It is rusted and fairly damaged from one side:
Slacken off clutch cable adjuster locknut to gain better access to the oil pump. Then take out the oil pump as well: Detaching gear shift pedal was a nightmare. In order to have better access I had to remove the front footrest assembly. Furthermore the gear change pedal was badly jammed into its splined shaft. I had to strike the spline shaft with quite a bit of force to get the pedal out. In short it was a decent amount of work. As you can probably see the crankcase cover is also damaged: Engine underside:
In general all over the bike the wiring appears to be totally messed up. It is going to be a nightmare sorting this out: Opening up right engine cover and draining the oil. Impact screw driver is your friend: Loads of oil came out, given the fact that it is 10 years old. Amazing ! Taking out the carburettor was an absolute nightmare. The rubber pipes providing fuel were as hard as steel which unfortunately had to cut using a sharp knife. As you can see some idiot mechanic had already taken +ve steps towards the destruction of the carb. I don't know what the hell was he thinking at the time: Back side:
I forgot to attach pictures of the lower chain cover: Taking off fuel c.o.c.k assembly from the fuel tank: (sorry but the annoying automated pakwheel language guard was replacing c.o.c.k with *** . So I had to put dots in between) Another view: The tank itself was relatively very easy to dismount: Spiders living in the tank LOL : With the tank and seat off this is how the bike frame looks like. Amazingly there was no visual or rust damage at all on the bike frame. The frame appeared to be in a very good health:
Important: Always be organised. Put everything separately and if possible, label them:
Rusty chain: Taking off generator cover: Loads of gunk in there as well: The rear number plate is off. Looks like someone had put a foam for the support lol: Rear fender is in a real bad shape:
Showing off the tools again Very important: Always use an impact screw driver when ever you are opening up exterior engine parts. The impact driver has extremely high torque. It loosens up even really soft and rusty screws easily and without deforming them. If you use the traditional mechanic recipe of normal screw driver and a hammer, you will literally "screw" up all your screws. Trying the impact driver on right side of the engine cover. Very soft rusty and deformed screws. Specially after applying WD40 they were as soft as butter. Fear not, impact screw driver to the rescue: Dismounting chain covers. Loads of rust on the chain: The chain covers are in a very bad shape due to rust. Specially the bottom cover is dissolved from underneath and has huge holes in it: Check out the amount of rust:
After banging my head on the wall for about 2 hours at last the seat is dismounted: Seat closeup, Rust: The carrier is also off and the bike looks like this: (which in my opinion is pretty cool. I think I should put a much smaller seat): Check out the rust at the bottom end of the tank. I think there were a few holes in it as well:
Carrier: (I think this is what its called!) Closeup shot. As usual huge amount of rust: Those damn rear seat bolts were driving me crazy. Tilted the bike flat on the ground for better access: Somewhere in there lies the devilish rear seat bolt:
Ripping the bike apart The first thing I planned to take off was the seat: But this proved to be way trickier than I imagined. Apart from being extremely rusty and crumbly, few of the bolts were virtually inaccessible. For example the rear seat mounting bolts which bind the seat to the frame. These are located vertically above the rear indicator light shafts. Due to very little clearance it is extremely difficult to get any decent sized spanner in there and loosen the bolts up: Applying some WD40 in order to soften up the rust: Removing relatively easier bolts: And I don't know why but I removed the rear shocks because I thought it would give me more clearance to the rear seat bolts. The bike carrier at the back end was also getting in the way, so had to remove that as well:
Thanks a lot . Yes I am labelling everything and trying to be as organised as much as possible. Thanks . As soon as I disassemble everything, specially the engine, after that I will concentrate on the frame and stuff.
More broken parts:
Spark plug seems to be in healthy condition. There are no oil, deposits or erosion on the electrodes, probably hinting that the engine was also in healthy condition (but let's see). By the way before taking out the plug or the battery I tried to start the bike (10-15 kicks) and there was absolutely no spark in the plug electrodes.
