PHILnFINGERS
Everything posted by PHILnFINGERS
  1. Hi, Further to coming off my Yamaha XJ900F, I am in need of some assistance please. Upon crashing the front right-hand indicator broke off, so does anyone know how to wire a new one in please? I've checked through Google Videos, but can't see any videos there, so any assistance would be much appreciated please. Kind regards with thanks Phil
  2. Hi, I am new on here so would like to know whether there is anywhere I can post a wanted item notice. Edit by DDT: yes, in the wanted items section or classifieds. This is for newbies to say "hello". Topic locked.
  3. Hello, I have a 2008 Yamaha YBR 125 motorcycle which is causing me headaches as it will not start. The bike initially would start in neutral but as soon as it was put into gear the bike stopped running, & now it will not start at all whether it be neutral or in gear. I have replaced the side stand switch, the CDI & ignition coil, but nothing has help to resolve the issue. With this in mind I would, I would very much appreciate if anyone could suggest anything else that I could try in resolving the problem please. Kind regards with thanks Phil
  4. Hi, I have a “08” Plate, Yamaha YBR125 bike which occasionally decides its going to play up! I will try to start it using the electric start & it fires up/turns over, but as soon as I put it into gear, the bike dies on me, & the battery warning light will flash for a few seconds. I will then try to re-start it by putting it back into neutral, followed by starting it by the electric start but again it fires up/turns over in neutral, but the second I put it into gear whether it be first gear or skipping directly to second gear the bikes dies on me. I have tried kick-starting it whilst its in gear but all I get is the flash of the battery light, but no firing of the engine, however if I leave it anything from 10-30 minutes, I can then start it as normal by the electric start…..??? I am a complete novice when it comes to bikes, but if I had to guess, might it be the spark plugs or starter engine causing the problem thus requiring replacement??? Thank-you in advance for your time in this matter….. Phil
