simonsickles
  1. simonsickles changed their profile photo
  2. hi all, introduced myself today, i have a 74 DT 250 it wont spark.the bike was running some time ago....bought a new 6v battery..ignition switch was buggered/ useless so i cut it off at the switch and found a 3 pin toggle switch..can you tell me if ive wired it up right? Power - red Accesories-brown Ground-Black not sure where the black/white wire goes..if i touch it on red or brown wire battery leads heat up and blows fuse..if i have it touching the black all is good but still no spark. managed to get the horn and blinkers rear stop light working though. but not the headlight.....i havent got the flywheel puller yet but the points open and ill clean them also....any ideas what could be causing the short? all the other wiring on the bike looks good and seems to be in the right spots....thanks simon.
  3. hi all just introducing my self here as ive just got a 1974 DT250 shitter.....i need help! Im usually on the honda twins forum as i have "a few" honda twins which i fix up customise etc....any way i got this DT250 and it wont fire but i got the horn and blinkers working...ill post up in the help section....cheers simon
