d4cl4n
Everything posted by d4cl4n
  1. Now the front two flash and not the back , thinking there's wire crossed somewhere in a terminal block. God sake who'd of thought inidicators were such a pain in arse
  2. Tried temporally wiring the relay to the brown wires going to the original relay and no result , may be stupid but should I have the engine running when testing them ? My engines been off the whole time
  3. Thanks for your help, il have to wait until Friday night to wire it up , its gonna bug me the whole week.
  4. No it has a kickstart which is why i'm kinda confused as to why it would have a starter relay
  5. Yeh i could do that , was just thinking about a quick fix but that would be more substantial. I also messed around with that relay under the seat and the wires may not be in the same place from what they came any ideas what problems that could cause ?
  6. I did see something behind the light, if i remember correctly there were two brown wires going into it, should i cut them and solder them to the blue relay ?
  7. Some of you have probably encountered this problem. Just wired up some new led indicators and they all flash when i turn them on. There was a relay that came with them but i have no clue if it fits anywhere as the relay under the seat is 4-pin and i cant find any other. Can you point me in the direction of something that will fix this , i know resistors work with it somehow but which ones. Thanks in advance
  8. Looking at supermoto'n my 1999 dt 125 r found some 17 " dt 125 x wheels but my question is will my dt 125 r's rear disk fit on the 17" wheel ? I know the front won't not sure on the back Many thanks
  9. Just recently bought a Dt125r 1999, been looking through this forum alot so just thought i'd make an account , will probably need help at some point because im looking to do it up a bit.
