boysireed23
  1. boysireed23 changed their profile photo
  2. hello i am chris reed from crook co.durham.. i have a dt125 re 0n 54 plate and i am having a few problems with it.. there seems to be a permanent live.. the ignition lights and head lights are on all the time even if i take the key out.. the bike will not start if i remove the key but it dose start if i put it in the off position . the bike will bump start and will start from another battery with jump leads..the battery is goosed i think as it only hold enough charge to power the lights it will not start it.. also when i am using the bike it will start to splutter and loose power sometimes it just conks out.. any help or comments would be much appreciated
  3. i am new to forums not sure how to say hi in members..switch all seems fine and relay is good tp i have been over all the loom and carnt find any problems.. could i put a secondry kill switch on the loom to stop it killing the battery
  4. i have a dtr 125 54 plate it used to start firt turn even when cold.. went out to go for a blast the other day and it would not start.i took out the key and the lights and neutral light on the clocks were still lit. the bike starts when bumped and if i jump it it starts aswell but as soon as it stops it will not start again even aftewr a long run out..
