Everything posted by finnerz89
YBR 125 Fault codes 12 & 33
Well if both those things are bosted you'll never get it to run. However I'd say it's unlikely that both components would break at the same time. Do you have a wiring diagram? I'd be looking for a common connection between the 2. I'm assuming your battery is in good nick and fully charged? Does the engine turn over off the starter but not fire?
Running down a harmonic DT vibe...
Those TWs are proper funky. But of a rarity over here and most are in really rough condition. Yours looks very clean though, nicer climate and all that! Glad you got the DT sorted
rd350ypvs rev counter wiring
Sounds like you need a wiring diagram
Introduce myself
Welcome to the forum! Sounds like you have a good project, start a thread in the projects section and throw some pics up! As for the frame no, don't the police etc sometimes use acid to show numbers that have been ground off? Might be worth looking into
NO PRESSURE REAR BRAKE.
Call me bubbles darling!
Stafford Show,
Mini YoC meet! Lol
Stafford Show,
Might pop down Saturday afternoon, working till 2 though, and again on Sunday. Typical when the forecast is so good!
FZR1000 problems
Have you tried Google for a manual? There's a couple of sites that have them for free.
2000 Fazer won't turn over.
Kill switch, sidestand switch, neutral switch maybe?
Speedometer wrong reading on xt125r
No. Why have you started another topic on this? I suggest you go over to the new members area and introduce yourself
XS250 Restoration
I use Flickr. It's free
- Xt600 2NF
- Xt600 2NF
Dim headlight on tickover MOT fail?
Normally I'd suggest looking at the regulator/rectifier but as you've said the light runs directly off the stator. I'd double check and clean all the connections from the lamp back to the stator and also clean up the earth points. Do you have a tester that can measure how many volts you're getting at the lamp?
If it's a common problem then I don't see why it would fail a MOT. Best thing would be to give your local tester a ring and ask
Dragstar 125 Clutch. (odd question).
Are you missing any spacers or washers? Does the pressure plate only go on one way?
Thunderturd 1!
Love the panniers on the red one lol
Centre stand rubbing against chain
Take it to a local bike shop or garage, I'm sure they'd be happy to tack something on for you for a tenner
- Txt 50 new member
Yamaha XS1100 hose hanging out?
Crankcase breather, definitely not a problem. Just tuck it up out of the way
Either a fuel overflow or crankcase breather. Usually a little bracket that holds them in place, nothing to worry about
tzr50 low compression
Have you checked the reeds?
XS750 tacho drive chewed itself
Plenty of flushing and a magnetic plug as above. You might be lucky, presumably it's been on the way out for a while so might only be small pieces not big lumps
not bike but a bargain,
Nice work, I'm keeping my eye out for a similar deal. Some bargains to be had out there.
- ~~Daily Feed, post what made you laugh today ~~
