finnerz89
YOC Member
Everything posted by finnerz89
  1. DE4 2EQ Sent from my SM-G950F using Tapatalk
  2. Preparations.... Sent from my SM-G950F using Tapatalk
  3. Fine by me. We can have a big brekky instead! Sent from my SM-G950F using Tapatalk
  4. Or this https://www.dropbox.com/s/34d0cmbtln0nk4x/YOC_Peak_District_Ride.gpx?dl=0 Sent from my SM-G950F using Tapatalk
  5. https://drive.google.com/file/d/1sxAkcdXoMFTbu_6Tn9mCAS4reXN0PnwV/view?usp=drivesdk Try this Sent from my SM-G950F using Tapatalk
  6. So.... route planned, I've tried to include some good landmarks etc, and some good roads too! Also planned in the tearooms that drew suggested. Screenshot of the route and gpx file attached for those with sat navs YOC_Peak_District_Ride.gpx
  7. Bloody hell! Sorry mate but that sounds like it would've been quite funny to see [emoji23] Get plenty of ale down you and make the trip, it was you that prompted this remember! Sent from my SM-G950F using Tapatalk
  8. No problem. I'll do it a bit more tonight, try and work in some tea breaks Sent from my SM-G950F using Tapatalk
  9. I was planning a route last night, not fussed about leading. Although I might get left behind otherwise [emoji23] Sent from my SM-G950F using Tapatalk
  10. Not long now [emoji16] I'm being lazy and dropping all my stuff off in the car first [emoji106] So if anyone needs owt let me know Sent from my SM-G950F using Tapatalk
  11. Yeah your room is booked mate [emoji106] I posted a while back that we were all sorted but you might've missed it. I'll be there early so look for some scruffy bloke loitering about [emoji23] Sent from my SM-G950F using Tapatalk
  12. With your torquey beast you'll probably only notice it at the pumps Sent from my SM-G950F using Tapatalk
  13. Probably an air leak if it's slow to rev down
  14. No problem. I'm sure we could sneak you in regardless. I'll drop the woman an email tomorrow. Sent from my SM-G950F using Tapatalk
  15. 8th/9th. I can ring up for you and book another pitch. Sent from my SM-G950F using Tapatalk
  16. I'd just go for DID X ring, gold if you want a bit more bling. Sprocket wise 1 tooth bigger on the front should get you what you want. Sent from my SM-G950F using Tapatalk
  17. finnerz89 replied to nickbird01's topic in Projects
    Check to see if YSS do a shock for it. Chances are they do. Good price and very good units, usually more adjustable than the standard one. http://www.yssshocks.co.uk Sent from my SM-G950F using Tapatalk
  18. finnerz89 replied to Cynic's topic in Reviews
    Bahco make some great kit. I use their adjustables every day. That's a good price for a kit that big Sent from my SM-G950F using Tapatalk
  19. 8th June, square and compass in darley dale ?
  20. Have you got the correct workshop manual? Could be something else holding it on
  21. No it should be much higher, 60v AC up to around 80. May well vary with engine rpm. Measure between the 3 yellow wires again
  22. Could well have bearing lock on it. Have you got a heat gun you can warm it up with?
  23. finnerz89 replied to Harlowbill's topic in The Bar
    Leaf springs
