Everything posted by finnerz89
		Aprilia 50cc rebuild.
		I used the vice at work to get the last of mine out. The outer races should press out but cutting will work Sent from my E6553 using Tapatalk
		Did the ones on my DT. Made a puller with some threaded bar and some sockets. Would be easier with a press though, one was a bitch to get out Sent from my E6553 using Tapatalk
		YBR 125 stalling with clutch in??
		Probably, if you know where it was before.... Post up some pics and we'll see Sent from my E6553 using Tapatalk
		You say you had a new ignition barrel fitted, could be that the clutch cable has been rerouted during this hence it acting like it's out of adjustment Sent from my E6553 using Tapatalk
		Regulator
		Tasky is right, best part of 13v without engine running. If you turn the ignition on then that might drop if your headlights are always on. With the Engine running anything near 15V will cook the battery. 14.2V at 4krpm would be considered ideal. (I think) Sent from my E6553 using Tapatalk
		Yamahas winning
		What a steal! Looking good Sent from my E6553 using Tapatalk
		TDR125 project
		I'm getting a romeu system for my DT [emoji106] Sent from my E6553 using Tapatalk
		Requirements to declare a shed, a garage.
		From my experience wood = shed. Some insurers class that as parked off the road, while some call it a locked building. Vast difference in price I've found Sent from my E6553 using Tapatalk
		DT125 stuttering at high revs? (Sound clips)
		Nice work! Sent from my E6553 using Tapatalk
		Just sounded similar to mine when it had the rev limiter on. Where did you earth the cable behind the clocks? I'd double check it's all good. I'm also assuming you have an aftermarket rev counter then? Sent from my E6553 using Tapatalk
		Is your bike derestricted? That's when the cdi starts to retard the powervalve to limit the power on restricted bikes Sent from my E6553 using Tapatalk
		What RPM does it start doing it? And what year is your bike? Sent from my E6553 using Tapatalk
		I know the feeling, having recently acquired an Aprilia myself. It's already costing me money! Sent from my E6553 using Tapatalk
		How long has it been doing it? Have you put fresh fuel in it since? Sent from my E6553 using Tapatalk
		Ice
		No choice for me, 2 wheels or no wheels. Thankfully the council around my way are pretty good at gritting Sent from my E6553 using Tapatalk
		Time for a change or an addition
		My Mrs hated the FJ for pillion lol Sent from my E6553 using Tapatalk
		Dual load equalizer
		Ohm's law will help you calculate the size of resistor you need. However the easiest option is to change to a solid state flasher relay such as this one: https://www.amazon.co.uk/dp/B002RB4D6M/ref=cm_sw_r_cp_apa_DErEyb9V09W6Y Sent from my E6553 using Tapatalk
		Depends what you make it out of. I keep my bikes in a wooden shed with a concrete base, and that gets regarded as a locked building with some insurers. I'd call it a garage given how substantial it is but they don't Sent from my E6553 using Tapatalk
		Yamaha Aerox R 2016 Help
		Getting something with gears would be my next suggestion if doing a test isn't an option Sent from my E6553 using Tapatalk
		My tips would be save the money and get a license and big bike Sent from my E6553 using Tapatalk
		Another toy! AND ITS ADORABLE
		Looks like you're getting quite hedgeucated foams [emoji23] Sent from my E6553 using Tapatalk
		This looks like fun!!!
		Epic! The Mrs says I'm not allowed lol Sent from my E6553 using Tapatalk
		Putting the feelers out.
		Looks like a good find! Sent from my E6553 using Tapatalk
		What is it?
		It's a DT of some description Sent from my E6553 using Tapatalk
		Name these tubes - YZF750
		Vac pipes I assume Sent from my E6553 using Tapatalk
_33963e.png)
    _83bc35.png)
