		wrong details on fine
		Ok I see the pnc check was carried out with me in the vehicle was stopped immediatly, the reg plate was read out and correct I have only realised after seeing on the government website the wrong details but on the ticket it would be easy to mistake because of the handwriting.
		Ok I see if he had the wrong registration written down in his notebook aswell would this make a difference or would he be double checking exerything first?
		No i have not payed yet jimmy, was about to but when on the court website my reg came up with 2 mistakes so have not payed yet also checked the slip I was given the u instead of v is quite easy to get mixed up but r instead of z is more obvious. To me this says when they have entered the details on the system both letters have been misinterpreted.
		Hello was stopped and given a nip for doing an illegal u turn a few weeks back and have just got round to paying online when I done this I realised 2 mistakes regarding my registration number online there is a u instead of a v and an r instead of z does this void the ticket? Thanks for the help.
		dt 125 re lost all electrics
		Problem sorted now cheers fuse had blew . The led was wired in with the original brake light but I couldnt get them both to light up when brakes are applied im guessing that the original draws the current away from the led ?? Cheers.
		Hello , I have an 07 dt 125 re which has an aftermarket tail tidy with led brake light which I was using along with the standard brake light. The led light would turn off when the brake was applied and the standard would light up like normal so today I decided to disconnect the led light and once I done this and turned on the ignition nothing happened. I'm not very familiar with electrics so any help is appreciated ! Robert.
		hello
		Cheers guys . Robert
		dtre coolant leak exhaust
		That's great really appreciated what payment method you looking to use?
		Ebay would be fine mate will let u know by Saturday. Robert.
		I'll give that a try cynic, would the coolant replace what was lost from the jacket once sealed after topping up the radiator? Thanks.
		Ok sounds good could u put it by for me, I should have the money by the weekend at the latest? I'll drop u a message asap.
		It was a very steady flow ken going to check the radiator see if theres anything left in there and I may be interested in the cylinder how muchu lookin for? Will i fitmy bike ok? Thanks.
		DT 125 R running poorly!
		I've heard this is pretty common with the big one exhausts and remember reading somewhere(90% posiive it was the dt forum) that adjuting th powervalve slightly to the right solved this problem.
		Thanks for the quick reply, the bolt looked to be the same size when lining the two up so I was shocked to see the coolant appear. It did stop when I put it back in but I'm not happy with running it atm I'm guessing a new cylinder won't be cheap either?
		hello guy an into a problm today when replacing exhaust bolts, after checking to see the bolt fitted i removed it and coolant drained from the hole, with my limited knowedge i think it has punctured a waterjacket. If this is the case would someone with more knowledge tell me hiw to repair this. thanks,robert.
robertdtr
Joined
Last visited
