yamaha red
Everything posted by yamaha red
  1. my 2009 ybr 125 has a switch on the clutch,so if you are in gear the clutch must be dispressed in order to start the bike...if this does not work try finding faults in the wiring system(whith a multimeter)
  2. hi there i have an 09 YBR 125 ESD, the rev meter/tachometer is not working anymore,it won't show above 5000 rpm(even at full taps),it used to work fine,ive already checked battery conections,and cleaned out dirty connections in the plugs behind the tachometer,I'm not shure if the rev gauge is mechanicaly driven off the crank,or if it is electronic...I prefer working on the bike myself so if anyone can suggest a DIY sollution for the problem...PLEASE HELP!!! - regards from SA
  3. hi there i have an 09 YBR 125 ESD, the rev meter/tachometer is not working anymore,it won't show above 5000 rpm(even at full taps),it used to work fine,ive already checked battery conections,and cleaned out dirty connections in the plugs behind the tachometer,I'm not shure if the rev gauge is mechanicaly driven off the crank,or if it is electronic...I prefer working on the bike myself so if anyone can suggest a DIY sollution for the problem...PLEASE HELP!!! - regards from SA
  4. Hi there i also have the same ybr 125 (one with bikini fering on headlamp) and it took a bit of time,but i finaly figuered it out...to adjust the main beam u have to take off the fering,once that's done,u will see a little knob on the back of the light,by turning this u are actualy adjusting the whole reflector behind the bulb witch then adjusts the angle of the main beam,As to replacing the bulb the whole headlamp fitting has to come off of the fering,and then just unclip the font part of the fitting to get to the bulbs. I hope this has helped,and best of luck to u. :-)
