Paul Phoenix
  1. Paul Phoenix changed their profile photo
  2. Cheers, like i said im not very technical, but im willing to have a go Is it an 'easy' issue to resolve? Just been topic hopping to see if anyone's had a similar problem from what I've read could the carb be flooded too?
  3. Hi airhead, its Carburated. I'm not very technically minded, but that is one thing I do know
  4. Hey dude, had the same issue, it seems this happens when you disconnect the battery or fit a new one. Put the key in the ignition, but don't switch it on, wait for it to flash 'endr' then switch ignition on, wait for it to flash from 'ntdr' back to 'endr' and press the blue mode button on left hand bar (if you have one) that should sort it.
  5. Hey guys, Went to start the bike, but wouldn't turn over, said battery was minimal, when i had it on the charger the other day said it was fine. anyway oiked out the kick start, it turned over with choke out, got the revs up for a minute and slowly let out the throttle, engine cut out, repeated the same process with same effect a number of times. It seems it will turn over but then just cuts out if I release throttle or put choke in... Any ideas? Regards Paul
  6. Hey guys after posting a few days ago it was suggested I pop in her and say a quick hello! Not the best end of the year for bikes, but can make some interesting rides! Cheaper than Blackpool pleasure beach. Regards Paul
  7. hey guys, just having a bit of an issue with the enduro/motard modes got ready to ride to work, and notcied a that ""Ntdr" and "Endr" were flashing, after a qucik look, on the internet, it would appear that this is to select motard/enduro modes, not thinking this would have a massive effect i pressed 'enduro' mode. after setting off the clock displayed that i was approx 10mph faster that i was actually going. bening led to believe that the enduro models have smaller tires, this would explain this, however after disconnecting/reconnecting the battery and selecting the motard mode, it would appear that the clock still displays the 10mph difference. can anyone offer a possible solution to get it so the clock speed and the actualy speed are correct? thank you regards Paul
