  1. got it to start wont rev or idle properly make a small clunk noise near the water pump then cuts out anyideas chaps??? ohh and the negative cable off the battery wasnt grounded to the frame the washer had snapped now replaced thanks lee
  2. ignore the that last comment there fine got motor tdc after compression stroke and valve clearance fine got it to run for about two seconds 3 or four times now should i check the injection part air filter ect again also my battery is on charge now??????
  3. looking at the valves they doesnt seem to be any clearance at all when turning over is that right ??
  4. tried new plug wd40 and induction chaps all clear can i check the exhaust valves without tearing it apart thanks again lee
  5. compresion is good to check the exhaust valve do i just take off the very top lid off the motor only 6 m8 bolts there?i will have a look tommorow as im waiting for a new plug to be delivered thanks
  6. no mate its fuel injected
  7. tried it no luck it sounds like it wants to tho a real headscratcher this one
  8. hi everyone ive got a 2010 yam wr125r problem was riding home and gradually revs got lower then conked out on me hasnt fired up since it turns over good spark and plenty of fuel as plug is wet tried bumping her off no luck any ideas many thanks lee,
