Everything posted by Tommy xs
Back to black
What's wrong with that
Back to black
I always paint it my self usually turns out crap but more or less the colour I wanted
Back to black
That's some painter you got, talk about colour blind how the f#ck can you get yellow & black mixed up ?
ybr 125
This thread is 4 years old Rich
Afternoon from Lincoln
Hi Chris welcome to YOC what bike/bikes you got
Y.O.C. 2018 meet,
Could be good but a bit close to home for me only about 15 miles away, although I already have a few bike things going on this year so means I could make it without adding more nights away which gives Mrs xs one less reason to pull faces.
Hi from Scottish Borders.
Hi welcome Ian there's a few xs250 threads on here, good luck and don't listen to a word Jimmy says
Back to black
Really good job there John like the black much better than the blue
Back to black
Should have gone to specsavers paul
YBR 125 Fuel Cap stuck
Try squirting wd40 into the lock also you could try taking the tank off, hold it upsidedown and swishing the fuel round in it(if any) to lubricant the internal mechanism of the cap then try what Drewpy said. Is you bike carb or fuel injection the reason I ask is cos on many fuel injection bikes you can remove the plate underneath which might allow you access to the underside of cap. If not remove pet tap, fill tank with water then carefully dremmel around lock on cap. If all that fails try Slices idea
Xs250 81 se wiring
First thing is to say Hi, pref with a bit of info in the new members sec. Up to I think 1986 you're only required rear brake pedel brake light, but as already said you need most it. Lots of info on this on xs400.com could also look up drewpys tracker project on here somewhere but I can't remember name of thread. If you do an intro you'll get a much better response
Yamaha XS250
Yep tis true they don’t like pods you will need bigger jets.drew will probably know although he upgraded his carbs to the carbs from the dohc then rejetted. I can’t remember if it’s the same on the older sohc but on my bike the carbs are both jetted differently owning to the shape of the air box so if that’s the case and it still has original jets they’ll be your problem
XS in distress.
- Yamaha XS250
Well I bought the xs400 dohc more than twice the mpg of the rd and only fractionally slower, never had any trouble keeping up anyway, will do a constant 80+ on the motorway and still going strong 36 years later, but must admit when I see the prices of Rd's now I realize I fucked up big time- Yamaha XS250
No you should get more than that, have you checked the breather pipe on carbs- Bad coil symptoms?
as above plug first, lead your way back from there- One for cynic,
- Drewps running the Manchester 10k
Good on yer Drewps I'll sort a donation in a couple of weeks when I next see a pay cheque, I've just been off for almost two weeks with no pay so scraping the bottom of the biccy barrel at the mo.- Ross Noble Off Road
Really enjoying this on TV what he lacks in ability he makes up for in pure grit, you gotta give the guy credit for taking this on and sticking with it (so far) every inch of him must be in pain and by day three don't think I would want to go on. Brilliant TV hope he makes it to the finish.- Santa runs
Working the weekend Drew, I was hoping to finish by tomorrow but its not looking likely, today I thought I could see light at the the end of the tunnel but turned out to be a train coming the other way.- Howdy from south Texas
Yep Slicey you're right my xjr will start but then cuts out if I put it in gear with the side stand down- Howdy from south Texas
Or side stand switch could be faulty or starter solenoid, first thing is to make sure all connections are clean and tight.- Howdy from south Texas
Hi harry try taking it off the side stand- XS1100 2H9 engine and frame color code ?
What you mean you don't mind chopping bits off but it has to be the correct colour!- Welsh TT CANCELLED
Gets my vote - Yamaha XS250
