j0hn
Everything posted by j0hn
  1. I have an XT 125X (2008) that has been locked away for the past 5 years after it failed its MOT. It required about £400 worth work to replace steering head bearings, rear wheel bearings and front fork oil seals but I never got around to it. Before I put it away, the engine was working fine with no issues, however, having sat there for all this time, I doubt it would simply tick over without some maintenance (oil/fuel change, new battery etc.). I'm probably going to get nothing in its current condition but could it be worth anything if I spent some time getting the engine running again at least? I don't see myself riding again so I'm looking to sell this off. I won't have the time or want to spend the money to get it to pass the MOT so I was hoping someone would buy it off me (minus the cost of repairs obv).
  2. Thanks jimmy and NE0, I'm going to look at sorting it out this week so will keep posted.
  3. Not sure what happened but my post disappeared when the Workshop sub-forum was restructured so posting this again. So I'm trying to bring my WR250F (2003) back to life again which has been stashed away for over three years now. It was working great before then and I even wrote up a project about it on here around 5 years ago (https://yamahaclub.com/forums/topic/37457-2003-wr250f-legalize-it-project/). Is there anything I should be doing first and foremost before I try to start it? I just want to make sure I'm doing everything right in case something gets messed up in the process. The bike is stored in a locked building so there is no worry of the elements getting to it. (1) There was almost a full tank of petrol in the tank (unless slowly evaporated). I carelessly left it in there without emptying it so I'm assuming this will need drained first? (2) I'm not sure if the battery would be completely dead, I'm thinking of plugging it into my Optimate 4 to see if it can revive it, otherwise I'd have to buy a new battery. (3) Air in the tyres, check tubes and lube the chains. (4) More than likely the engine oil will need replaced? (5) Replace coolant? (6) Need to check if the brakes have seized. (7) Will the spark plug still be ok? (8) Go around squirting WD 40 for good measure. Please let me know if I've missed anything other than the listed above or if any of the steps are unnecessary. I hope I don't have to end up pulling the engine apart and clean the carbs as I'm definitely not experienced enough to do that. Also fingers crossed the engine hasn't seized.
  4. So I'm trying to bring my WR250F (2003) back to life again which has been stashed away for over three years now. It was working great before then and I even wrote up a project about it on here around 5 years ago (https://yamahaclub.com/forums/topic/37457-2003-wr250f-legalize-it-project/). Is there anything I should be doing first and foremost before I try to start it? I just want to make sure I'm doing everything right in case something gets messed up in the process. The bike is stored in a locked building so there is no worry of the elements getting to it. (1) There was almost a full tank of petrol in the tank (unless slowly evaporated). I carelessly left it in there without emptying it so I'm assuming this will need drained first? (2) I'm not sure if the battery would be completely dead, I'm thinking of plugging it into my Optimate 4 to see if it can revive it, otherwise I'd have to buy a new battery. (3) Air in the tyres, check tubes and lube the chains. (4) More than likely the engine oil will need replaced? (5) Replace coolant? (6) Need to check if the brakes have seized. (7) Will the spark plug still be ok? (8) Go around squirting WD 40 for good measure. Please let me know if I've missed anything other than the listed above or if any of the steps are unnecessary. I hope I don't have to end up pulling the engine apart and clean the carbs as I'm definitely not experienced enough to do that. Also fingers crossed the engine hasn't seized.
  5. The // actually makes the URL protocol relative, meaning that it will use whatever protocol you are currently using to browse the site, unlikely to be the source of the issue.
  6. j0hn replied to captf's topic in Video Section
    Yea totally agree, just a shame he lost the bike. The driver not slowing down does play a pretty big part in this. It seems more like he was a bit inpatient and didn't wait for the buses/traffic to clear. If he had, it would have allowed him to crossover into oncoming traffic on the major road before turning into the minor. This would have meant his vehicle would be in a position similar to the illustration above where he might have only crossed over half the lane the rider was in, putting him in a better position to see the rider. I always ride under the assumption that they don't see you and work my way up from the worst case scenario. The size of the vehicle and the blind spots were just not in favour of the driver or rider in this instance though.
  7. j0hn replied to captf's topic in Video Section
    Without being too controversial, could this situation have been avoided? I know it's easy for me to type this without actually being there and knowing the factors that would affect your decision so this all just an analytical breakdown of the video. Could a bit of defensive riding have saved his bike? I don't condone what the driver did after the collision and as captf has already mentioned, the blind spots definitely didn't help the situation. Also, the way the driver reacted to the whole thing might just be the fact that he is in shock, but again, not the point I'm trying to make here. It's obvious that a vehicle of that size is going to have a larger turning circle and has been stated in the Highway Code (221). I know the illustration isn't the same as the road layout in the video but what it's trying to show is clear. The truck will, more often than not, crossover into oncoming traffic and drivers are advised to stop and wait if it needs room, which the rider clearly did. Around the three second mark, you can see through the metal railing that the truck has been indicating before approaching the road, obviously very difficult for the rider to notice so this was just to make sure the driver was properly indicating. I think the five second mark is crucial, not sure what rider was trying to look at, hopefully it was just an early shoulder check and not checking out the girl that walked by. I'm just guessing here but it's crucial because I don't think the rider noticed the indicator at this point and in turn, didn't realise the driver's intentions. First point I'll make is, had he focused on the road ahead, would there have been enough time for him to stop sooner, knowing the driver was already milking the extra room needed? Not putting this entirely on the rider because I think the driver should have waited for the buses/traffic to clear to get a better turning circle. Around six seconds, the driver can't see the rider and he showed no sign of stopping, rider is unaware. Around seven seconds, the rider realises this and let's say the shock of it prevents movement but still able to shout a warning. Around nine seconds the rider is able to save himself by using the crash momentum to roll off. I believe the rider was still in gear at this point because I couldn't hear any clutch noises coming up to incident and the engine seems to rev up and stall when he came off. Second point, around the time the rider realises the driver wasn't stopping (which is around seven seconds), was there enough time for him to ride across to the other lane? He did his shoulder check so should know the lane is clear from behind/sides and nothing is coming from the front on that lane. This really depends if he was in gear, if not, then the odds are higher. I know this opens the rider up to a whole lot of legal issues if moving over develops into something more. It may even be more dangerous if the rider didn't position himself in a safe place after moving as the driver still wouldn't be able to see him so potential to be caught by the rear wheels as the truck was always going to end up back on the right lane after some time anyway.
  8. So only two bolts in and already having issues. No matter how much pressure I put on the hex key, I just don't think there is enough torque to slacken the axle. I also don't have an 8mm hex bit so I'll probably have to order a 3/8" hex bit set that has an 8mm bit. Even if I hack my way into getting it lose, I'll need the bit for my torque wrench anyway when I have to tighten it back up again. This set should be good I think: http://www.amazon.co.uk/Silverline-225127-Hex-Drive-7pce/dp/B00IV1SBV0/
  9. Thanks for the tips so far. I've watched a few YouTube videos and some did suggest using the old bearing to push the new ones down. Hopefully I won't have to battle too long getting the old ones out, I'll see how I get on.
  10. Hey KevtheRev, I'm planning to start this either on Monday or Tuesday. I was even contemplating taking Cynic's advice and have the forks alone done by a mechanic but will see how I get on once I actually manage to get the forks off. Congrats on getting all that done in an afternoon! I'm thinking this might be a job over two days for me and I also need to do the rear wheel bearings as well. Last time I did that, the difficult part was getting the race out and ended up having to take it to the mechanic to have it pulled.
  11. j0hn replied to drewpy's topic in Video Section
    Yea must be a hell of a lot of trust. I remember watching this Boeing video where it was almost a vertical take-off, imagine the power out from those engines .
  12. j0hn replied to Grouch's topic in The Bar
    Didn't you use to keep the bike inside Grouch? That would count as a locked building contributing to a much lower premium.
  13. j0hn replied to Grouch's topic in The Bar
    Just curious how you're planning to rig one up, is it to the bike or somewhere in your garden (door)? From what I can remember, you need to pull a pin for it to activate. I take it you'll attach it to the garden entrance like some sort of trip wire? Trying to think if there would be any legal workaround for the appropriate use of steel jaw-traps, wouldn't even need an alarm to hear anything then .
  14. Just to add to what slice has already mentioned. This could also happen when you have either disconnected the battery or if it's low. You might have to look into getting a new battery if it's old. What you are currently seeing on the dashboard is the options to select from after a reset. Since the same dashboard is used on the R and the X model, you need to set it to the correct one. Since you have the XT 125 X, you need to wait until it displays ntrd then turn on the ignition and after the second flash of ntrd, press the blue button on the left handlebar (at the front).
  15. I think that might just be the case lol, mine is still running great *knock on wood* .
  16. The forks on this haven't been touched for years so I guess they'll be in some state. No doubt I'll have some difficulty unscrewing bolts on the way but see how I go. Although, I think I might need a c-spanner, don't really have anything that would resemble one and tapping it out with a flat head might not be the best idea?
  17. Ahh, from what I've seen, the races for the head bearing could be troublesome as well if they are stuck tight.
  18. This is some next level shiz. I'm surprised by the degrees of freedom that nose knob has.
  19. So looks like it's time to tackle something new again . I'm having to replace the fork seals, which will most likely include a full service on the forks as there seems to be signs of leakage. Also, the steering feels a bit "notchy" and was told the head bearing might need replaced as well. I've hopefully got the parts I need to get started: 2x head bearings, 2x dust seals, 2x fork seals and fork oil. However, before I get started ripping the bike apart, I was wondering if I could get some advice on what tools might be essential to carry out the jobs. For those of who have seen my other projects and repairs, I have a decent array of tools to carry out most jobs. Having watched a few videos online, there seems to be a lot of specialised tools (bearing driver, race puller etc.) that I might need to consider, would be great to know if these would actually be essential or if there would be a reasonable alternative method to carry out the same task. Currently, I have a c-spanner in my basket ready to be purchased, any more tips and advice would be much appreciated, thanks .
  20. Hey metalmikky, I've actually got the Endurance II on my WR and installation was pretty simple. I would say the only bit of real DIY was having to drill a bit into the calliper to hold the magnet sensor in the correct place. I've been running it for over a year now (rain/shine) and no problems with it yet. Just make sure you get the correct fitment for your XT.
  21. Thanks for that. It's sad to hear all the ego boosts riders seems to get with an IAM certificate which seems to permit them to ride as they please lol? Riding experience wise, two years on two wheels this August and I've covered over 15,000 miles in that period. I actually bought and read the Roadcraft book well before I passed my bike test and I do read it from time to time, it is indeed a great read . I guess the best thing to do now would be to keep riding, hold off until I get on a bigger bike and after some experience on that, I could look into doing an IAM. They also advice people to wait until they've been on the road for more than an year before taking on any course. I'm thinking of maybe trying out the car assessment at least to see how well I'd do on the advanced test since I've been driving for over a year now. I've heard of RoSPA but didn't look too much into it. I'll have a look, thanks.
  22. Is that the BikeSafe workshop or something local? None of the local forces seems to be offering it sadly . Would have went 'cause it's a free course .
  23. I've always wanted to do one but I wasn't sure if it was worth the cost. I'm not doing it because of the "possible" reduction to the the insurance premium but to better my riding skills I guess. It's apparent that's not always the case since I did Pass Plus for driving and there was no reduction to the premium with it (even though the insurance company has stated that they do). Institute of Advanced Motorists (IAM) caught my attention and they do a course, test and one years membership for £139. The only worry now is that I'm still riding around on the XT 125 X which struggles to obtain 70mph on the motorway. So I might just have to wait until I move up because I think I read somewhere that as long as your bike can go above 70mph then it's suitable for an advanced riding test. If that's the case then I could always do the advanced driving test on the car and do the bike one later. The plan is to do an advanced test for both vehicles . Has anyone done one of these and is it worth it ?
  24. Haven't really had the time last few months . Things should be settling now and I should be here more often. Just the other day I took the WR out, on the road though. Only because it has been sitting in the house for a while and didn't want the engine to seize. Summer coming up and now that I'll have more time, I can finally take it off road . I've only been on the car a couple of times, thus far I've still been riding around on my XT and I'll always be loyal to my bikes .
  25. Lol, around 1:30, guy running face plants just off the screen.
