Kaapie
  1. Campaman thanks for suggestions, tried options, but still had problem, eventually took it in to workshop, clutch plates needed replacing. Problem has been solved. Thanks again.
  2. Hi everyone, been watching the site for a number of months, had my XVS650 cruizer for only 6 months, and now decided high time to join. Riding a bike has been a dream for many years, now we are there, but I know nothing about bikes, and would appreciate help where needed. Thank you.
  3. Will do to both and thank you for suggestions.
  4. Hi all, I am new to chat room as well to motorcycles. I have a problem hopefully someone can give some guidance on. I was using my cruiser to do the license test and it requires slow movements using clutch and rear brake. All was good at start clutch in good position and working well, but after test I noticed clutch taking right at top end, if that term makes sense, and when accelerating it was slipping. Almost the take point had moved to immediate depression of the clutch handle, even maybe being engaged a bit when handle released. Not sure if there is possibly damage or is all I need to do is make adjustments to cable tension near clutch handle. Any advice would be appreciated. Thanks
