kenDAWG
Everything posted by kenDAWG
  1. Yes There is 2 hoses comes from the top of the head weird isn't it? Fingers crossed its just a slight adjustment needed otherwise Someone else can do it for me Ken
  2. Turning the carb to the side was a no go!!! Coolant inlet/outlet too short then there is that bottle ontop of the inlet needless to say everything else seems to go past either side of the carb and the fact the rubber from air box to carb has now decided to come out I have to strip the bike down a bit I managed to get to it but its too tight to put it all bak together. I got the slide out and the needle clip was right on the top notch so I've dropped it one, once I get better access to the carb ill get it put back together Cheers for the help Ken
  3. That is a good point lol-----/\ I would have had her in bits by now. Will there be damage caused if this diagnosis is wrong? Ill order a new spark plug and do a chop also Cheers Ken
  4. Yeh that's the thing it isn't a 2 min job, I should have some spare time Sunday so ill get on it like a car bonnet! I'm going for the clip to richen it, I've just sprayed up the exhaust and put her on no leaks ill just check the intak.... Normally a squirt of compressed air around the area can indicate air leak while engine is running. What a chew on Cheers for the help pal Ken
  5. kenDAWG replied to Grouch's topic in The Bar
    Is that the style of bike your thinking of changing too? I couldn't get away with the position on my nsr 125 I found it horrible. Have a look at the dtr's they have a bit poke and hold there value well I wanted one of them cagiva supercity 125's its like a supermoto uses same engine as Mito but someone mentioned the 7speed box isn't as reliable Ken
  6. Some of the info I picked up "On a 2-stroke - Riding in 3rd gear, with a warm engine and the throttle BARELY cracked open, roll the throttle to 1/2. If the bike sputters and crackles, and you feel like you have to keep rolling on the throttle to smooth it out, the needle is too rich. If, on the otherhand, you get the dreaded 'buhhhhhhwaaaaa', the needle is too lean" I for one am not confident enough to mess with jets and I haven't got the time with the bairn teething I only have limited time and I fill that with checking oils and cleaning her! Could be a trip to westgate road for me there is a garage there who specialise in 2 smokers says he will tune the carb for £35 Ken
  7. It's just the information I have been picking up of the Internet! My air box has been butchered by previous owner as well-rather than a slot in the top where the snorkel goes the top has been opened up! Don't know where to bloody start! Ken
  8. Just been out on it there! 3rd gear doing about 30mph I roll the throttle 1/2 turn and and just bogs and starts juddering off the throttle than give her a little turn of the throttle increasing slowly no problems... I'm sure its running lean I really can't be arsed with this crap. Before I done the topend there was a rattle that's why I freshened her up, small end bairings where on there way out the rest was fine checked the bore etc and it still had cross hatching and no marks what so ever but I changed them any way! Ken
  9. So ill have to get the carb off it again, its a bloody nightmare Cheers Ken
  10. Well after the breaking in period of my top end rebuild my little dtr isn't running like it was... I'll try to explain as best I can. Bike pulls away perfect up to and beyond powerband 1st,2nd however I notice in 3rd its not revving up to the line a little hesitant then 4th is the same I can't open full throttle as I get a "burrrrrrwaaaahhhhhhh" like its wanting air drop off the throttle a little and away it pulls again same in 5th I don't even get into 6th as I can't get her into the powerband enough in 5th so 6th just drops off the revs. I've cleaned out the petrol tap and fitted new washers etc, run through full tank of petrol with wurth 2 stroke additive, cleaned and oiled filter, decoked power valve and set her up, changed plug, cleaned carb and a few other bits and bobs Am I running lean? Is it a case of adjusting the needle clip to richen it up a little? It can't be the jets surely as the bike was running well before the topend rebuild!!! Cheers Ken
  11. kenDAWG replied to Baker.Ben's topic in The Bar
    Yeh there are people in her who could tell the carb from that information, wait and see what other people suggest. Once you know the make and model of the carb you can start looking in eBay! If the dt125r carb is the same I'm sure there is a member in here selling one if not i have delt with a person on eBay who is parting his dtr Ken
  12. kenDAWG replied to Baker.Ben's topic in The Bar
    £400????? Your kidding me right? I'm sure the dt125r carb should fit, what make and model is your carb? Ken
  13. kenDAWG replied to Grouch's topic in The Bar
    There a decent road tyre pal not really enduro as they state they are but on the road they have some decent grip. I had the matching front tyre but I didn't rate it at all so it in the bin. Everyone has there choice of tyre I can't say its better than your choice but they have good reviews and at £15 rather than £55 its a steal but money is money Your call dude, do some reading up Ken
  14. Powder coat the swing arm aswell pal will look more tidy-black frame/swing arm with chrome exhaust and blue plastics should look clean and tidy I'm not sure on the plastics mind the dt plastics seem to be a little bit more flexible as there not fixed solid especially the tank fairings and I'm thinking they may crack over time! There may be some flexible kinda spray paint out there but I don't know! Ken
  15. Foamy there are some classics in there like hahah. I put my full dep exhaust on and plastics back on only to realise I hadn't put the exhaust gasket it. Over adjusted the rear brake when changing the wheels only to be found doing 20mph with bright red disk on a 60mph road with no chance to pull in for 5mins. Run out of petrol when pulling out of a junction only to have to jump off and push like fuck before both lanes of traffic killed me. I think that's all for now Ken
  16. kenDAWG replied to Grouch's topic in The Bar
    I got a Heidenau catspaw rear tyre here pal done about 100miles, ill sell you for £15+postage it was fitted to my dtr 18"...... Ken
  17. So much empty space in the frame must be for side winds lol... The person who done the should have really shrunk the frame down and made a mini version now that would have Been interesting Ken
  18. kenDAWG replied to BillyBennett's topic in The Bar
    Up front opposite side of the tank to the radiator! Expansion tank is on the left hand side rear panel it uses the frame work instead of tubing an is prone to blocking (poor design really) Ken
  19. kenDAWG replied to BillyBennett's topic in The Bar
    What year dt is it? Mines a 2003 and sitting on the bike, up front right hand fairing (opposite side to radiator) is where my 2t oil tank is Ken
  20. Get it on its feet and sell it pal I wouldn't even use it just get her cleaned and tidy put mot on it and get rid plenty of learners wanting 125s Ken
  21. Is it the full driving license that allows you to take your test on a 50cc auto and be allowed to ride up to a 125 geared on L's?
  22. kenDAWG replied to dtluke's topic in Yamaha Workshop
    Honestly I don't think it should cause any concern as the expansion chamber is attached to the exhaust port then there is a lug just before the exhaust makes its way round from the front of the bike and its ridgid as hell... Once the end can is in and bolted up the whole system is solid, no give on mine! Ken
  23. kenDAWG replied to dtluke's topic in Yamaha Workshop
    Is it the one just before the break in the exhaust before the silencer fits in?
  24. kenDAWG replied to dtluke's topic in Yamaha Workshop
    Which one of the mounts doesn't line up? I think if its either one of the points before and after the expansion chamber it will be alright but if your talking a couple of points altogether its a no no unless you can cut out some stainless tabs with a dremel and drill in a couple of holes?? One of Mine doesn't line up the one after the expansion chamber (heading to the endcan) and with all the other mounting points tightened up the whole system is solid so it doesn't worry me Ken
  25. This is the way I do mine with the same cheap asse bleeder thingy lol!! Ken
