alanfsz
  1. I am thinking going the other way drop down a bit, looking at fitting a modernish top fairing anyone done this on a xj900f?
  2. Yes sorry I got that wrong now sorted and runs fine
  3. Ermm not quite, it ran perfect then it went on two again, stripped carbs down and found 2 pilot jets were nearly falling out, wondering wether to locktite them into position 2 turns out
  4. well it seems ok going for a short test ride, once again thanks for info
  5. Many thanks never touched leads coils since owned always ran perfect until now, by the way new coil has just arrived about to fit so will soon see what happens
  6. As title says it is running on two outside pots, inside pair run on same coil so I have a new one on the way, but I am curious would a faulty ignitor be the cause as I am unsure if it would run on two. Any info would be appreciated
  7. This sounds obvious bats not holding charge, but my headlight is also not working even with another battery. any thoughts
  8. took plugs out and she appeared to be running a bit lean so I raised the needles up one notch and what a dfference she pulls like a train now,
  9. As title says it runs ok up to 4000revs then hesitates then charges on, had carbs off cleaned jets Im wondering plug leads? any thoughts
  10. As title says just got no nothing about these might need some help.....
