garside
Everything posted by garside
  1. Anybody out there.... In forum Land !!!
  2. Thanks for your reply but the wiring in question is part of the original wiring, the alarm is aftermarket and the solder joint have been removed. Aftermarket alarms are usually easy to remove as they are spliced in it the original wiring I have removed countless alarms from cars no problem, not up on bike wiring just need a hand with the wiring routing then can get her going again. Thanks anyway
  3. hi, tried looking for wiring diagrams but none of them show black wires with white squares. all i can find is the a diagram showing similiar routed wires going into alarm connector, but the alarm is an aftermarket datatool therefore i must be missing something. thanks all the same
  4. hi everyone, a friend recomended this site he said you helped him out of a hole last year.... anyway i have a yzf thundercat, just removing alarm as playing up big time, problem is i am left with 4 wires white squareall black with intermittent white squares. one comes out of cdi unit (presumed to be plastic box fixed in front of battery with three plugs in unit) with 12.5 supply (ignition switchable), another has battery voltage slightly higher at 13.8 (ignition switchable)located at one of the gang plugs at the back of the battery, the third seems to be starter command wire as when you put battery live through it starter turns on thumb switch, the fourth seems to be connected to the stand switch as when you check resistance level it changes according to side stand switch position.traced the fourth wire through the loom and it goes to a connector and turns into a blue with black strip heading towards the ignition. i can't seem to find to correct combination and it driving me crazy. only took it for mot yesterday passed but now in pieces............
