albertaglen
Everything posted by albertaglen
  1. Hi. Does anyone know if the alloy-rimmed rear wheel from a 77-ish xt500 (or even the alloy-rimmed wheel of later model dtmxs) can replace the steel-rimmed stock wheel of the 75/76 dt400s? Thanks in advance.
  2. albertaglen posted a topic in The Bar
    Hi. Does anyone know if the rear wheel (with alloy rim) from a 77-ish xt500 or even the alloy-rimmed rear wheel from a later-model dtmx can replace the stock steel-rimmed rear wheel from a 75/76 dt400? The wheel bearing ID is the same. I know that the brake backing plate is different between later model dts and the 75/76 wheels, but a suitable replacement from a xt wheel (or even possibly one from a 75/76 dt) will likely work. Any help would be appreciated.
  3. Hi. Does anyone know if the rear wheel from the 77-ish xt500 (with aluminum rim) or even the later-model dtmx rear wheel (also with aluminum rim) will bolt onto a 75/76 dt400 (which comes stock with steel rim)? The wheel bearing ID is the same. I understand that the monoshock dts have a different brake backing plate but a xt one (and maybe one from a 75/76 dt as well) will likely fit. Any help will be appreciated. Thanks.
