azzybigc
  1. hi ive had a look at my bike this morning these are the things ive noticed i started the bike 1st kick, it seems to run fine apart from what it thought was a oil petrol leak i think its just fuel! it drips very fast from under the gear foot peddle behind the sliver plate the carb seem fine no leaks around that area pipes are dry when i switch the fuel tap off it stops say 30ish sec later the dripping
  2. thanks for you time professional will get you some clear answers tomorrow
  3. sorry pal thanks for your help im trying my best this bloody dyslexia makes it difficult ! will look at it agian tomorrow and get my wife to type
  4. im not sure it looks fine no leaking from the carb its dry from the out side
  5. cant see any over flow pipes leaking as i say looks like its under the left hand side case cover where it joins the main body
  6. norm starts first kick but now its like its flooded
  7. its just looks like its got oil in it its not clear as petrol is its darker and it smells like its go some in (off head now) lol
  8. hi mate it looks like its coming for the fuel tap side near the side stand because it was runing down the side stand its not leaking now drained the fuel tank took the side cover off and not leaking from the oil tank,
  9. ive look at all the pipes going from the fuel tank
  10. hi ya i would say no not really! ive drained the fuel tank as well
  11. hi all i need your kind help again ive got a looks like a fuel mixed with oil leak on the left hand side of my crank case look like its coming from under my bike driping at a rate of knots down my side stand have you guys got any ideas what it could be?? my haynes manual been no help !! thanks for you time
  12. hi mate i try not to go to fast really just go with the follow of traffic on 60 roads i go the speed limt but thats it! i might look like a fat bloke sitting on a roller skate at 15 stone but ive not done alot with it i had some battery problems so changed that should i start looking at the air filler of the bathels ??
  13. ive had my rxs 100 for a month now after a few teething problem its a great little bike the only thing is im getting poor gas milage! it says that the tank hold 9 ltrs but at the pumps i brim it and i can only fit 6.5 ltrs in and on that 6.5 ish litres im getting 80 before hitting the reserve tap im not the lightest bloke in the world but still ive heard people saving they get 100 mpg!! to cut a long story short is there anything i can do apart from loose weight i check the tyre tp and oil and thats about it as im not very mechanically minded please any advice would be greatly appreciated thank azz
  14. cheers roberttjames i will have a look at doing that im not very good with electrics so wish me luck lol how much mpg do you get on yours?
  15. hi all i was wondering if anyone could help me please ive just get a rxs 2 weeks ago and my indicators dont work properly the front ones are very dim and the back ones bearly flash at all ive changed the battery for a new one and looked at the bulbs the flasher relay looks new what could it be? also does anyone know the mpg for these its a great bike but it would be perfect if i could get that sorted thanks all azz
